[LA] lt1 6 speed swap
lt1 6 speed swap
The only thing needed is a shifter and pedals. $1300
6 speed transmission and crossmember has a little over 80000 miles
spec steel flywheel and stage 3 clutch
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: lt1 6 speed swap
im interested. is it a t56. will it fit 350 tpi.l98 how much?
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
what kind of shifter is that? Will you sell that separatley?
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
I'm looking for one of these, but seeing as I don't have the cash I'm not going to waste your time. Hope you sell it.
Car: 88 IROC-Z Hardtop
Engine: 305 TPI Auto
I'm interested if you could post the numbers off it and year the car it came from. I could do about 1k if interested. Text me at 832-477-5435, want to let my mechanic see the numbers and pictures first.
Thanks,
Chris
Thanks,
Chris
1992 Trans Am
08-08-2015 08:16 PM
