[Sold] Paxton Carb Enclosure Box, Great shape!
For Sale, Paxton Carburetor box, this encloses your carburetor when you are supercharging or turbo charging your engine. It pressurizes the entire carb instead of just the main body.
The only modification you will have to do is put brass floats in your carb so they do not collapse under pressure.
The purpose of the carb being fully enclosed is you do not have any pressure leaks in the throttle shaft and fuel leaks around the throttle shaft.
$175 plus shipping. This is ready for your Supercharger or Turbocharger setup.
Straight from Superchargersonline.com
This universal assembly will allow the use of a centrifugal supercharger or turbocharger on carbureted engines. This unit is designed to fit Holley 4150 flange carburetors (including Demon brand carburetors) and will clear most Ford and Chevrolet standard distributor caps.
1992rs/ss
16
01-28-2016 09:58 PM
toronto formula
11-10-2015 06:17 AM
box, carb, carburetor, centrifugal, enclose, encloser, enclosure, making, paxton, pressure, pressurize, purpose, sale, supercharger, turbo
