GM 700-R4 Valve Body with B&M Shift Kit
Car: 1992 Camaro T-Top
Engine: BUILDING 99 Vette LS1
Transmission: TCI Super Street Fighter
Axle/Gears: New Motive 3.73
This is a genuine GM Parts Throttle Body out of my 1990 Camaro IROC 700-R4, it has a TCI Transmissions stage 2 shift kit, torque convertor lock up kit, corvette servo kit, boost valve kit, random springs, check ***** and valves with a separator plate. I have also provided instructions from TCI Transmissions; it has less than 100 miles on it since the rebuild and new valves and springs. The lock up kit has to be soldered into the connection unlike the cheap plug in systems that will corrode and unplug themselves with time. I have provided links to see the value of this kit versus what I’m asking. The total value of this kit is $414 I’m asking $250.
Valve body Info:
http://www.compperformancegroupstore...ct_Code=376020
Servo Info:
http://www.compperformancegroupstore...ct_Code=376003
Boost Valve Info:
http://www.compperformancegroupstore...ct_Code=374301
Shift Improver Kit:
http://www.compperformancegroupstore...ct_Code=376500
Call or text for more pics,
Seth (910)603-7962
Valve body Info:
Servo Info:
Boost Valve Info:
Shift Improver Kit:
Seth (910)603-7962
