[WI] Th400 long shaft & light weight brake drums & ford 9's $ eagle H beam rods
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
a th400 long shaft out of a 1t 2wd truck worked good when pulled. $350
a Pair of machined down steel drums for a 84 Camaro they weigh 7lbs each. Lighter then aluminum drums ones. $120 obo
2 ford 9 rears with 5x5 bolt pattern hubs with third members around 62" wide have leaf spring pads on them.. $150 each
New in the box eagle Esp rods with arp bolts pn 356-crs5700b3D
$400 obo
$400 obo
