[IL] Rare 3.45 posi aussie 9 bolt, with the large aluminum pbr brakes
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
rearends in great shape,brakes are good doesnt make any noises, no gear whine.
450 obo.
this is an 89 rearend, 1 year only from what ive read, 3.45 factory ratio, factory posi,factory LARGE disc brakes, factory aluminum pbr calipers.
450 obo.
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Re: Rare 3.45 posi aussie 9 bolt, with the large aluminum pbr brakes
would be nice, but you're too damn far lol. and shipping would be up the rear (get it!? har har).
bump for a good deal.
On Probation
shipping id imagine would be in the 150/175ish range with my discounts.
id be willing to meet halfway for the cost of fuel as well{i like road trips}, shows you are roughly 750 miles each way.
On Probation
it works great, its just the last "weak link" that i know of in my driveline, only reason for sale is to go 9 inch.
It comes 100% complete, i think i need to keep the ebrake cables though for my new rear?
Zionsville is about 140 miles from me, im sure with an extra pair of helping hands it could be pulled in 30 minutes or so.
Let me know!
Car: 87 GTA
I'm trying to figure out where you get the 'rare' or '1 year only' from.....
9-bolts ran from 87-92.
All 89-92 had the aluminum PBR calipers & larger discs than the 87 & 88 9-bolt discs.
You want 'rare'? Find a drum braked 9-bolt! Not exactly a really desirable item, but by the numbers? Rare.
On Probation
this is by far, the most desirable factory 3rd gen rearend made.
Car: 87 GTA
I'll give it to you, that 3.45s are 'rare' (less common), but everything about the rest of the rear from 89-92.
I see 3.27 9-bolts left & right all day, for as low as $100. 3.45s are only a gear swap away & you'd have brand new gears not 20 years worth of use on them.
Good luck. I wasn't trying to shoot down your sale here. I just hate seeing the word rare thrown around so easily, when often times it turns out that the item isn't actually rare.
On Probation
but like i said, a factory 3.45 geared rear, with a posi that works great, and makes NO noise...is a rare thing these days.
ive had TONS of interest so far, but nothing concrete, im a little negotiable pricewise to those interested.
it has its worth with those looking for a better ratio, or those looking to do a resto and wanting 100% GM parts...
it is exactlly an 1 year only rear it's the only year where you can get an 9 bolt posi with the aluminum pbr calipers and 12 inch disc brakes by far the best option rear for our cars, it's rarer than the 90-92 10 boltrs with 3.42 rear so if someone out there has an 89 1le car or looking for an numbers matching rear you better hop on this these don't come around often or at all,
bye the way bump for a great deal !!!!!!!!!!!
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
I thought the 9 bolt was first used in 85? My 85 originally had a 9 bolt 3.08 non-posi aluminum drum rear end in it.... not trying to hi-jack the post, consider it a bump! Too bad your not in Buffalo, NY area or I would make a reasonable offer!
Tim
Tim
interested in the rear end, let me know if you still have it, my email. Transman7384@aol.com
JamesC
hectre13
12-11-2023 08:14 AM
Eric-86sc
04-03-2016 03:52 PM
