[TX] Pocket Programmer 2, Moates Adapter, and 2 ECMs
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
This is a programmer/burner for creating custom tunes for TPI cars. I bought this almost 5 years ago. In addition to the burner you need some sort of prom editing software. If you search thirdgen.org or ask around you will get a wealth of information. Includes everything the bruner uses, 2 non-UV erasable proms, and the Moates piggyback adapter for your ECM. This uses the parallel port on your PC. You can buy a LPT1 to USB adapter at any computer store for around $10. Asking $170 SHIPPED for everything.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Pocket Programmer 2, Moates Adapter, and 2 ECMs
What ECMs are u including in this sale? Did i miss that somewhere? I might be interested cause ive been going back and forth between megasquirt and just learning to burn chips.
Engine: LS1 V8
The 2 EMC's in the picture are the ones included. One is loose and one is in the adapter. I bought all of this from Transtronics several years ago and these are the chips they said that were needed for a '88 IROC-Z with a 350 TPI V8.
Engine: LS1 V8
TTT Still for sale. Make me an offer and Paypal accepted.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
>>>EDIT<<< found mine in the bottom of the box, thanks anyway
Engine: 355 TPI
considering this thread is from 2010 im voting no.
