[Sold] Lingenfelter Plenum & Runners
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Complete with all fasteners, cable bracket, lid, etc.
The standard mods of slotting the outer runner to plenum screws and Heli-coiling the inner 4 holes for bolting from within have been performed, so it is actually possible to install.
The cast lid is slightly warped (as they all are) but flattens out and seals perfectly when bolted down. No silicone needed!
The parts have been painted with cast aluminum paint and sealed with high-temp clear so they haven't oxidized and stained. They still look new after spending 2 years on the car.
$250 shipped.
$250 shipped.
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Re: Lingenfelter Plenum & Runners
Does it need anything else in order to install onto a TPI motor? Do these bolt onto a stock tpi intake base? If so I'll take it. Do you have paypal?
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
So it's 4 bolts have been heli coiled...? Just so you can install them with the lid off, vs having to try and reach from underneath?
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I will take it pm me your paypal info.
Josh
Josh
1 Post
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Can I get a couple of pics of the backside were the booster and vacuum lines go into the plenum? I just want to make sure this isnt a scam. Thanks.
Car: 88 Corvette
There's also a hole for mounting the MAP sensor. If you have MAF, the hole must be plugged.
To the other two questions, yes, and yes.
Lingenfelter didn't supply the small vacuum fittings, they have to be transferred from the stock plenum.
Gentlemen, PM me if you want it. Luke gets first dibs.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
"Scam"? A scam would be a crack in the casting, not a missing 2 buck 90 degree brass hose barb available at any hardware store. Nevertheless, the Lingenfelter-supplied brass hose barb is there (for brake booster).
not accusing you, just it looks worse when someone responds like you did
good luck with the sale, thats a really great deal
1 Post
Car: 87 GTA
Engine: 385 sbc
thanks, I just wanted to make sure the pics you posted werent from someone elses photobucket account (or whatever) so I asked for a different angle. I always get nervous when theres a good deal but the seller has no feedback and a low post count. Is it still available?
Engine: TPI350
Just to let you all know I'm waiting on him to reply to my PM. He said I was first in line. I'm sending him money as soon as I get his paypal information.
Royal_Z
09-30-2015 08:45 PM
1988, big, corvette, gta, intake, ligenfelter, lingenfelter, linginfelter, mouth, plenum, sugestions, superram, timing
