[FL] FS: Megasquirt II Assembled, Jim Stim, Wiring Harness, LS2 Injectors, TPS, IAC +++++
Well after investing alot in my Megasquirt II system for my SBC I've decided to go to a supercharged blow thru carb system.
So heres an almost complete package that includes:
- Assembled, tested, and working Megasquirt II V3.0
- Assembled and working Jim Stim with Wheel Simulator
- Megasquirt Wiring Harness
- 8 LS2 Fuel Injectors pulled from a 4k mile GTO
- New LS1 IAC with Pigtail
- New LS1 TPS with Pigtail
- New GM 3 bar MAP Sensor with Pigtail
- New GM Open Element IAT Temp Sensor with Pigtail
- New GM Close Element Coolant Temp Sensor with Pigtail
- Including Serial Data Cable and Power Supply for Bench testing
$600 takes it all
$600 takes it all
