[Sold] FOR SALE: Complete TPI Engine
I've decided to do an LT1 swap.
I'm selling my entire 1986 LB9 engine with 700r4, with all that is needed to do a complete install. I figured some guys with V-6's or non running engines would really like this deal.
It's still in my car, and it runs great.
9.5:1 Compression
416 high output heads
Strong running engine
Tranny has TransGo Shift Kit installed
I'm asking $999.00 for everything--engine, tpi, distributor, Accel Supercoil, 8.8 mm wires, plugs, ecm, wiring harness, maf sensor, snorkel intake and K & N filters, tranny, nice Hedman shorties, and anything else I forgot.
I'm going to advertise this locally here in Wyoming, but I would like to help out someone on here, if they're interested.
I accept PayPal. You can call me at (307) 399 1696
9.5:1 Compression
Car: 1988 Pontaic Trans Am GTA
Engine: 350 Tuned-Port Injection
Re: Gauging Interest-Complete TPI Engine
if you have a detailed list of the parts included, i would be very much interested
Car: 90 Iroc-z tune port 350 mod
Engine: TPI 350 chipedout neck breaker tran
Transmission: 700R4 built
Axle/Gears: 7.5 10 bolt rear end
yes i have a 3.1 rs 90 camaro and i love the tpi system that you have i really want one to put in my car but why are you parting out the car is there something wrong with it or no title let me know you can e-mail me at gieselonnie@yahoo.com or text me at (615)347-1996 my name is lonnie but you can call JR thaks for you time
Text sent.
The only reason I am selling it is because I am doing an LT1 swap, with the 4L60e tranny, as well. I got a sweet deal on a wrecked 97 Camaro.
I just want too much power, I guess--he he.
Nothing is wrong with my setup at all, with the exception of the tranny needing a valve body swap ($40 or so, for the valve body). I am pretty darn sure that the throttle valve is sticking in the valve body, and that is the only problem I know of with my setup. I have not used the tranny in the "D" position for a long time now because it doesn't downshift when I stomp the gas, and it shifts too quickly when upshifting (stacked shifts).
The engine runs great, and everything else is working well. The tranny is electronically controlled, and it has a new governor assembly, along with the proper springs for the shift kit that is in the valve body.
You don't HAVE to swap in a new valve body, if you don't mind manually shifting the auto tranny (I've become a pro at this--I actually prefer it now over using "D"--he he). When it is in "D" it doesn't downshift when you stomp the gas--I have narrowed it down to a valve body problem. My current valve body has the TransGo Shift kit in it, so you would probably want to swap the shift kit parts into the new valve body (one in which the throttle valve moves freely). Dana at ProBuilt can send you instructions on what holes to drill in the new valve body, so that the shift kit works perfectly.
There are no other problems with anything in my entire setup. It's not super fast, but it's not slow, either. It moves the car right along quite nicely, even with the little camshaft that GM put in it in 86. That can always be addressed, though, by getting a better camshaft, by porting/prepping the stock 416 heads, and with some tuning.
Details of my setup-This list should be pretty complete: it will all remain assembled and ready to drop in (minus the engine oil because I'll drain it before I ship it)
I ran fuel injector cleaner through the gas tank every other tank, for the last three weeks and once a month before that time period.
Complete 86 LB9 305 tpi engine minus the A/C compressor
9.5:1 compression
Flat top pistons
416 heads (these are great 305 heads to port and polish at home)
Stock valve covers
700r4 tranny with Transgo Shift kit installed
Starter and alternator and aluminum Weiand High Output water pump
All required pulleys, belts
Full tpi intake (runners, ported upper plenum, and tpi base)
Fuel rails and injectors with stock fpr
Stock HEI distributor with Accel SuperCoil, plus new cap and rotor
Accel 8.8 mm racing wires
NGK Iridium spark plugs (almost 7 bucks a plug)
Stock throttle body
Air intake assembly (dual snorkel, K & N filters, MAF sensor, and TB to MAF rubber coupling).
ECM and wiring harness
front fuel lines
Part Number 68470 1 5/8" Hedman shorty headers
I may have missed something small, but it's probably something that is still on the engine that it needs anyway (ie, harmonic balancer, oil pan, etc.)
I'll throw in the oil gauge that is installed on it right now (mechanical sender with separate oil gauge--and I'll throw in the stock coil--which I replaced a week ago with the Accel, and the smog pump and bracket if you want it).
9.5:1 compression
Flat top pistons
Stock valve covers
Stock throttle body
front fuel lines
shipped to 23227 if parting out? email pics to game_ova223@yahoo.com
I'm hoping to sell it all as a package deal to someone, but I'll see how it goes in the next few days, and I'll get back to you. I'm going to post pics up here in a minute, too. It's all still in my car, and it is still in running condition.
Pictures posted. I had the headers sand blasted, then I cleaned them further and painted them with black VHT paint, which is holding up nicely. You can't tell in the light in the pics, but the plenum is polished only up to 600 grit sandpaper, and I haven't hit it with aluminum polish yet.
In case you're wondering, I also sanded off the dual snorkel plastic because it had little dots of paint all over it that wouldn't come of, so it is ready to paint, too.
I love my car and take good care of it. There is nothing wrong with the engine at all. I just thought an LT1 swap would be a very worthwhile swap.
Here's the 97 I found:
A woman called me from that phone number you gave me, and she said I have the wrong number. Might want to check the number you gave me. he he he
he he sorry its 374-1996 haha sorry you can call me now if you like
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: FOR SALE: Complete TPI Engine
would you sell harness and computer seperate. let me know if so and how much + shipping to 63368
ya i though about it and if i do sell it i would take 400 for it and the tran because thats what you can get for a good used v6 off the webb site just for these bodys and im not one ro try and make a killing off some one and then it get back to eithers because then that would be bad busizz and then your the one that looks like and *** know what i mean ha ha ha
i should have and answer son brother im working as fast as the army will let me haha you know the ropes but i will call the s1 in the morning and i will tell you this week but like i said for first come first sur
Car: 1986 Pontiac Firebird Trans Am
Engine: 350 Small Block Bored .30 to a 355
Axle/Gears: 3:73
A few guys are promising me money for the entire setup. If this weren't the case, I'd part it all out and sell the harness to you. You'll find one here, though, if you keep looking.
Did you post a "Parts Wanted" thread in the classifieds?
I know he would take 999.00 for it.People drag around much longer and I might end up with it,I got one without a motor,one I'm fixing to buy that needs a motor,and one that needs to be tuned up and drove..My house starts in 8 days and then I will have work for 10-12 solid weeks.Now days thats about as far ahead as anyone can plan
hey what going on bro. i like the video you sent me i was going to tell you that i can get the 400 from my motor that i can give you as soon has i call the guy in the morning and see whats up with him
ya i havent heard from you bro are you talking about me or have you sold it to someone else because im about to have the money soon and i need to know
#45
hey thanks man for giving me your time. i just found a guy last week that sold me a tuneport 350 with a 125,000 for 350 motor and tran plus shipingbut who wa you going to use to ship that motor i was just wondering
#46
I used NPT--they even came out and picked up the engine and tranny and hauled it off for me.
It cost $421.00 from here to Pennsylvania.
Check out my swap thread: https://www.thirdgen.org/forums/ltx-...ver-v-8-a.html
The_Phoenix
09-03-2015 10:56 PM
R3500
08-17-2015 12:16 PM
Sanjay
08-12-2015 03:41 PM
