[WY] Retro roller cams, lifters, rockers, AFR 210's and more
I have the following for sale:
- Crane retro-fit roller cam. 222/230 at .050 with .509/.528 lift. $150 obo
- Crane retro-fit hydraulic roller lifters. $250 obo (cam and lifters have about 5K miles on them and are in excellent condition)
- Harland Sharp 1.6:1 full roller roackers (not self aligning) with poly locks for 3/8" studs (new, never used, but not in the box): $200 obo
- Edelbrock retro-fit roller cam (p/n 2101). 234/238 at .050 with .539/.548 lift. New in the box with cam lube. $200 obo
- AFR 210 heads (the last generation before the Eliminators). Completely rebuilt with new hardware. 72cc chambers, 2.08/1.6 stainless valves, dual roller springs with viton valve seals. $850 shipped
Re: Retro roller cams, lifters, rockers, AFR 210's and more
Pics added...will take more if desired. Forgot to add that heads have been professionally repaired (with aluminum) around the chambers...you can see where in the pictures. Heads have been decked down to 72cc chambers after repair to clean up the surface. Can take more detailed pics of heads if needed.
Car: Hot Wheels
Engine: Stroker 383
whats the lobe separation on the crane cam, does it have the steel dist. gear, with the rust, how long have they been siting
LSA on the Crane is 112 degrees. It has an iron distributor gear...there is no rust. They've been siting for about two years inside and have been in zip-loc bags with oil. Wyoming is dry as a bone anyhow, not much rusts here.
Oh...I see what you mean by rust...it's not rust, it's the color of the cam surface. I can take a more detailed picture.
I'm interested in the RPM cam for a SBC but I would need some 7.3" pushrods to go with it. Do you by chance have any of those as well?
New2Chevy
09-28-2015 12:35 AM
