1989 PBR disc brake PROPORTIONING VALVE
Car: 1991 z28 vert/91 rs vert/85 TA vert
Engine: stock tpi 305/tbi 305/tpi 305
Transmission: 700r4/ 5 speed
Axle/Gears: 4th gen rear in progress/stock
This valve was removed from a 1989 formula 350. It had front steel calipers and rear aluminum PBR calipers. A must have if doing a drum to disc swap..... $60 shipped USPS priority mail...
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
Re: 1989 PBR disc brake PROPORTIONING VALVE
i am interested i have a 91 camaro rs that i want to put i 9-bolt pbr disk into but need the valve. do u take paypal???if so i will purchase asap (as soon as u respond)
Don't mean to meddle, but just thought I'd point out that the threads were different on most of the 89 prop. valves compared to a 91. GM changed the thread pitch on the lines going into the valve right towards the end of 89. I had to figure out which thread pitch I had on my 89 before putting a new valve on it. Turned out to be the earlier style.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps the following will help:
1st design: M1.0 tube nut threads (For 1982 - early 1989 applications)
2nd design: M1.5 tube nut threads (Late 1989+)
Good luck to buyer and seller.
JamesC
JamesC
I sold the one from the formula. I do have another from an 89 iroc-z, same disc setup, front steel and rear pbr aluminum calipers. $60 shipped
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
1989, 1991, 86, 89, brake, camaro, dementions, disc, gen, images, proportining, proportion, proportioning, size, thread, valve
