[OR] pbr 9 bolt swap caliper brackets (and rotors)
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
EDIT: these are in PA. I don't know why the heck it says oregon. And if you're close enough to want to pick them up in allentown, pa, that's fine by me.
I have a pair of PBR swap caliper brackets for a 9 bolt rear.
These are rare, since they were only available from the factory in 1989. This is a cheap way to get a much better rear brakes on your iron caliper disk rear, or upgrade from drums. The calipers came on 89-97 f-bodies (and other applications too), but 90-97 only came with 10 bolt rears, so while the rest of the brake parts are pretty easy to find, or you can still buy them at autozone and the like, but the mounting brackets aren't so easy to come by.
I also have a pair of used rotors too, if you would want them. I don't have the calipers, because i'm using them on another project.
$75 plus actual shipping - either for the brackets alone, or the rotors and brackets. The rotors are free, but you have to pay shipping on them if you want them, and they aren't exactly feather weight.
Engine: 355
Re: pbr 9 bolt swap caliper brackets (and rotors)
no interest? price is somewhat negotiable.
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
you take 50 plus shipping for them? If so I will take them
lmk
lmk
Engine: 355
i'd rather not go quite that low. i'd do $60 + shipping.
Thanks,
Alex
Thanks,
Alex
evilstuie
01-09-2020 08:29 PM
Eric-86sc
04-03-2016 03:52 PM
red90IROCls1
08-25-2015 06:56 AM
