TH 400 & Spohn Crossmember
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I have a TH 400 transmission & Spohn Crossmember for sale. The transmission was Built by Bowler Performance transmissions ( http://www.bowlertransmissions.com/ ) It has never been used or bolted in since I had it built. The case is powdercoated red and inside, it has a hardened imput shaft, reverse pattern manual valve body & a transbrake. This is a nice tranny and also has an aftermarket pan. I also have a Spohn crossmember that I bought from a guy on this board that is in like new condition, sorry, no torque converter. This was built to be a bulletproof set-up and will withstand a lot of power. I'll take $1200 for the tranny and crossmember "shipping not included". I will separate the tranny & crossmember, but only after I have a buyer for the transmission.
BTW, I have a factory folding rear hatch panel that is covered with grey carpet. It will probably need to be cleaned, but is in great shape $70 Shipped "have no use for it since I tubbed the car".
If you have any questions, shoot me an e-mail.
Thanks, Bruce "70GTO"
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Re: TH 400 & Spohn Crossmember
How much for just the crossmember shipped to 54944; very interested!
Car: 89 Iroc Z
J/K, I really would rather not split the two up unless I sell the transmission first. If that should happen, you are on the top of the list.
Thanks for the interest,
Bruce
Car: 89 Iroc Z
No one out there's needing a TH 400! This will make someone a dynamite tranny!
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
too bad ur so far away how old is the tranny? why u getting rid of it?
Car: 89 Iroc Z
Bruce
Car: 82 Firebird
Engine: Boosted LSX
Hey if you still got the crossmember for sale im very interested in it. You sent me a pm earlier in the week. Lemme know if its still available.
Car: 89 Iroc Z
I'll sell the crossmember by itself if anyone's interested!
Bruce
Bruce
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
I am interested. How much shipped to 95624.
Do you still have the receipt to verify the internal parts used?
how much power was the trans built to handle, does it have shift kit? im overhauling the driveline of my friends gta and need a trans that can handle 500hp, how many spline is the tailshaft? (not that big of a deal) can have money in a week
Car: 89 Iroc Z
It will be tomorrow morning before I can give you the spline count "I'm at work now". This transmission was built to handle serious HP and I was going to put it behind my smallblock that is turning out right at 575HP. As far as a shift kit goes, it has a manual valve body, so for it to shift you must do it manually with your shifter "kinda like a manual transmission that doesn't use a clutch". If your friends car is turning 500 horses, this transmission would be a perfect match. If you have any other questions get back with me.
Thanks, Bruce
Thanks, Bruce
Car: 89 Iroc Z
Car: 89 Iroc Z
Car: 89 Iroc Z
emz229, The tailshaft is 32 spline. BTW, where are you located at?
Bruce
Bruce
Car: 89 Iroc Z
Car: 89 Iroc Z
At the moment ,I have a few people that are interested in it "as a package deal with the transmission", so I'd rather not part with it by itself just yet. If by chance everything pending should fall through, I'll contact you.
Thank you for the interest, Bruce (70GTO)
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
kammi10
11-09-2015 08:28 PM
darwinprice
17
10-11-2015 11:51 PM
tmork454
09-29-2015 06:33 PM
1992, 400, 86, camaro, cross, crossmember, crossmembers, crossmemeber, gen, member, parts, sale, spohn, thirdgen, turbo
