TKO-600 / Stealthram / Dart Heads
Car: 86 Cutlass
Transmission: 200-4R
Due to my project car rotting out on me, I'm selling off some of the stuff I've collected over the last few years.
Up first is a Tremec TKO-600 (.64 OD version). This has been installed in the vehicle, but never ran. Slight bit of corrosion on the input shaft are where the throwout bearing goes, but could be cleaned up without much work. Included with it are:
Ram 11" flywheel - never ran but has surface rust, will need to be sand blasted or surfaced before use
Centerforce Dual Friction 11" Clutch - never ran, but the pressure plate side might need to be cleaned
Poly trans mount
Hurst shifter and shift **** (spec'd it for a G-body, might not work with an F-body)
Speedo output, back up switch, neutral plug
Output shaft yoke
3 Qts GM syncromesh
$1750 OBO for all of it. Would prefer pickup on this.
I've also got a set of Dart 180cc Iron Eagles (74cc chambers) with screw in studs, guide plates, LT1 valve springs, hardened pushrods, poly locks, and a set of the cheapie Summit 1.6 roller rockers (not "true" roller rockers, only roller on the valve side). The heads have 2.02/1.60 valves and were ported by myself years ago. They are port matched to a Fel-Pro 1205 intake gasket. Has the 87 up bolt pattern and centerbolt valve covers $350 OBO.
Next up is the fuel injection setup that was on top of my old engine. It includes:
Holley Stealth Ram intake / fuel rails
stock 48mm throttle body
set of 8 22lb and 8 42lb (if you're interested) fuel injectors
Distributor / Coil
GM 7749 ECM (includes ZIF socket)
Needed engine sensors (including 2 bar MAP sensor)
This is the setup I was running on my 350. I was running the 749 ECM on a modified harness from an 87 TPI car, which is where the throttle body and distributor came from. I can provide the wiring harness out of the car, but it has been modified quite a bit as I removed any unneeded wiring from it. The Stealth Ram is a bit dirty in the pictures, I'll clean it up and get some new pictures of it. $500 OBO
Pictures of stuff can be found at http://s273.photobucket.com/home/DJackson1357/index. I'll update as I get more pictures.
If you're interested, you can respond here or email me at DJackson1357@yahoo.com. Some stuff can be shipped, some can't. If it can't I'm willing to drive a bit to meet if you're close. I'm located in central Indiana.
Poly trans mount
Output shaft yoke
3 Qts GM syncromesh
Distributor / Coil
Re: TKO-600 / Stealthram / Dart Heads
interested in the stealthram. please contact me if it is still available. chad@skyshift.com
92projectcamaro
01-18-2016 09:00 AM
