[NC] PARTOUT.....86' IROC/LS1 Swapped**
Car: 1986 Camaro Iroc Z28
Engine: 325ci. 6bolt skirted main
Transmission: Built stg2 700R4
Axle/Gears: 3.42 Posi disc rear
1986 Camaro IrocZ28
*If your interested in a part, request a price for it, no shipping on anything larger than a rim, but im not shipping rims/tires*
--Also whole car for $4300
5.3L v8 swap
-Est. tune HP 360 rwhp
-Z06 cam(LS6)
-C6 intake(LS2)
-LS1 injectors
-Billet rails
-Aeromotive reg.
-ceramic shorties, no cats, rear o2 delete
-egr delete
-no ac, no heat
-motor had 65k miles before i freshened her up with the boltons
-ive put close to 500 miles since that.
exhaust
-4th gen ceramic shorties wrapped
-front o2's
-no cats, rear o2's deleted
-2.5" y pipe, merge into 3" single out the back through 1 super 44.
-exhaust is mocked up, functional but not pretty, nasty welds, good for exact copy at exhaust shop though.
700r4
-Stage 2 transgo shift kit
-3200 stall
-deep pan
-stage 2 build on internals
(borg warner, transtex, and kevlar)
-500 miles on trans
Exterior
-3" cowl fiberglass hood
-1st gen z28 emblem in RS grill
Wheels
-275/40/zr17
-Camaro ss/Zr1 5 spoke chrome
-need to be freshened up or painted
-front tires are bald
-rear tires are nitto drag radials, 70% tread.
Fresh suspension up front
-Poly bushings for upper control arms, 36mm sway bush and endlinks, new ballJoints
-Cross drilled slotted rotors, new pads
-new struts
2002 rear suspension swap
-2002 Z28 6spd car rearend and full suspension
-3.42 POSI rear disc setup, new pads
-4th gen mast cyl.
-rear sway is 24mm from iroc, with poly bush
17 gal fuel tank
-walbro 255 lph pump
- -6AN fule line
-inline filter
-steel braided lines in engine bay
-aeromotive fuel regualtor w/ boost reference
autometer guages
-digital fuel level
-volts, oil pressure, water temp are analog style
-monster tach w/ light
-5 inch speedo (mechanical)
2002 Z28 interior mods
-dash and center console from 02' car
-has rear carpet but no front carpet yet
-have original door panels
-rear black plastic pieces
-no head liner for t-top
-two reclinable black racing seats can use 4 point harnesses
( one seat mounted, other is not)
Runs and drives, but needs some more fine tuning. Tuned by mail order through pcm4less.com. Needs paint, minor body. Needs interior finished. Wiring is intimidating, but simple.. toggle switch for everything right now(went for race ease).
7049622166 Justin $4,300 for whole car.
Charlotte, NC
5.3L v8 swap
-Z06 cam(LS6)
-C6 intake(LS2)
-LS1 injectors
-Billet rails
-Aeromotive reg.
-egr delete
-no ac, no heat
exhaust
-front o2's
700r4
-3200 stall
-deep pan
-500 miles on trans
Exterior
Wheels
-275/40/zr17
-new struts
-4th gen mast cyl.
17 gal fuel tank
- -6AN fule line
-inline filter
autometer guages
-digital fuel level
Charlotte, NC
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
Re: PARTOUT.....86' IROC/LS1 Swapped**
How much for the engine alone? Do you have a pic of the the door panels? I am interested and am located in NC!!
Car: 91 Formula ex-1/4 mi. car
Engine: LS1/LS6 SLP maf K&N cai 3" exh
Transmission: built 700R4 w/ 10" HUGHES 3300stall
Axle/Gears: MOSER AXLES, 3.73 w/ posi
STILL HAVE THE ZR1'S FOR SALE? ARE THEY OEM 17X9.5"?
THANX
THANX
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
how much for zo6 cam and the aeromotive stuff?
Car: 1984 Camaro
Engine: 305 4bbl
Axle/Gears: stock :(
how much for the dash and center console? do you also have the dash pad?
how much for the ls6 cam? also interested in emblem and hood
