083 heads, 165 ECM, accel 30lbs inj. crane hi6s igntion box
Old 02-18-2010 | 10:12 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Going LS1!!!! dont need it anymore!
like new aftermarket bluestreak distributor [ 3000 miles] paid $200 $90
1989 165 ecm remanufactured $100
iroc factory exhaust manifolds with air good shape $35
accel 30lb injectors, ran just over a year ago all working well, probably not even 2000 miles on them.. one missing pintle cap they cost like $1.50 $70
083 350 tpi iron heads running 2 years ago on GTA $170
crane cams igntion box and coil hi 6s new never used $ 150
http://www.summitracing.com/parts/CRN-6000-6302/
SOLD
vortec stealth ram
vortec fuel rails
accel 24lb injectors
AFPR
Rockers
Old 02-21-2010 | 11:27 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: 1.6 rockers,vortec stealth ram, 58mm TB, TPI, AFPR
bump
Old 02-23-2010 | 02:12 PM
Car: 1989 IROC-Z
Engine: 346 LS6
bump... lets make a package deal
Old 02-23-2010 | 02:21 PM
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
are the rockers self aligning?
Old 02-23-2010 | 02:27 PM
Car: 1989 IROC-Z
Engine: 346 LS6
no.. guideplates needed
Old 02-24-2010 | 10:51 AM
Car: 1989 IROC-Z
Engine: 346 LS6
sale pending on regulator
Old 02-24-2010 | 12:09 PM
inthe10s's Avatar
Are the rockers for 3/8 studs? Whats the price shipped to 08873 NJ?
Old 02-24-2010 | 12:17 PM
hooks2u's Avatar
Want a title? Post!
Car: 86 gt fastback fiero
Engine: 383 stroker
Transmission: 4t60
Axle/Gears: 3.33
Do you know if my non vortec hsr fuel rails will fit your vortec hsr??
Old 02-24-2010 | 01:04 PM
Car: 1989 IROC-Z
Engine: 346 LS6
hmm.. im not actually 100% sure.. you might need the vortec specific rails... on summit the vortec rails have a different part number than the regular ones.
Old 02-24-2010 | 05:47 PM
hooks2u's Avatar
Want a title? Post!
Engine: 383 stroker
Transmission: 4t60
Axle/Gears: 3.33
ahh ok I thought maybe it was just the front cross over tube was different
Old 02-25-2010 | 09:11 AM
Car: 1989 IROC-Z
Engine: 346 LS6
i think the difference is the crossover tube.... i cant see holley actually making different offset rails for one application.
if you can flare 3/8 fuel line then you can make another peice.
Lee
Old 02-25-2010 | 04:27 PM
Car: 1989 IROC-Z
Engine: 346 LS6
bump.. lets make a package deal
Old 02-26-2010 | 02:31 AM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
Hey man I want that Intake and fuel rail
Old 02-26-2010 | 02:36 AM
88Trans-am's Avatar
how did your tranny hold up with the power it made? is it built, just have a shift kit?any recommendations?
Old 02-26-2010 | 08:43 AM
Car: 1989 IROC-Z
Engine: 346 LS6
kirban reg sold
tranny is rebuilt, corvette servo, transgo shift kit, heavy duty pump and what not.... tranny held up fine. biggest enemy with the 700r4s is the heat. i have a big truck cooler on mine.
do you want a shipping price or would you come pick it up?
Old 02-26-2010 | 02:12 PM
88Trans-am's Avatar
let me know the shipping price. if it's not much i'd rather do that, but i guess your not too far away so it doesnt really matter.can you send me a private msg with your number or info that'd be great
Old 02-26-2010 | 03:03 PM
Car: 1989 IROC-Z
Engine: 346 LS6
PMed you
Old 02-26-2010 | 06:52 PM
hooks2u's Avatar
Want a title? Post!
Engine: 383 stroker
Transmission: 4t60
Axle/Gears: 3.33
I wish I could have gotten the hsr from you but I saw you were in Canada and the shipping to me would be to much, good luck on your sale
Old 02-27-2010 | 09:36 AM
89irocz28350's Avatar
Car: 89 Iroc Z-28
Engine: 5.7 350 TPI.
Axle/Gears: Borg Warner 9bolt 2.77
Do you still have the 58mm throttle body, and pictures of it?
Old 02-27-2010 | 04:57 PM
Car: 1989 IROC-Z
Engine: 346 LS6
sale pending on intake, rails, and 24lb injectors
yes i still have the throttle body
did you see the link to the other thread with the pics?
it comes with iac, and tps... two wear marks on the front from the hood.. see other thread for pic.... also i had to epoxy a stud in for the tps. so instead of two socket head cap skrews holding it it is a socket head and a nut. nothing wrong with it and works fine but is there
Old 03-02-2010 | 09:09 AM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: 1.6 rockers, 58mm TB,MAF, 083 heads, headers,
bump.... also have a hypertech eprom for 165 ecm.. 350 tpi auto..... is the thermomaster.. still have box .. $70
Old 03-11-2010 | 08:14 AM
Car: 1989 IROC-Z
Engine: 346 LS6
BUMP...
Old 03-11-2010 | 08:42 AM
Car: 1989 IROC-Z
Engine: 346 LS6
pm a offer if you dont like the price
Old 03-11-2010 | 03:02 PM
Car: 1989 IROC-Z
Engine: 346 LS6
new prices
Old 03-13-2010 | 06:11 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Bump
Old 03-14-2010 | 12:57 PM
89formy383's Avatar
still got the headers? how much shipped to 52349?
Old 03-14-2010 | 05:11 PM
Car: 1989 IROC-Z
Engine: 346 LS6
yes still them, i will box them and weight them up and get you a quote tomorow.. did you want the ball flanges with them?.. they are welded on but i could cut them off if you wanted.
Lee
Old 03-14-2010 | 06:11 PM
89formy383's Avatar
the flanges are fine man
Old 03-15-2010 | 09:19 PM
1hotroc's Avatar
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
How much for the throttle body shipped to 06810 USA if its available. Total cost please.
Old 03-16-2010 | 02:04 PM
Car: 1989 IROC-Z
Engine: 346 LS6
pics of 083 heads
Attached Thumbnails 083 heads, 165 ECM, accel 30lbs inj. crane hi6s igntion box-img_4713.jpg   083 heads, 165 ECM, accel 30lbs inj. crane hi6s igntion box-img_4711.jpg   083 heads, 165 ECM, accel 30lbs inj. crane hi6s igntion box-img_4712.jpg
Old 03-16-2010 | 04:44 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
My car is identicle to yours. A 1989 IROC black with grey interior 350 fully loaded. I have changed it to 90-92 dash and speed density with air bags; that was hard. let me know about the throttle body shipped to 72104. Do you still have the 9 bolt and did yours come with 2.77 gears also? Changed mine to a 9" ford with 375 locker.
Old 03-17-2010 | 09:34 AM
88Trans-am's Avatar
hey man. can you post a pic of those headers., how would that ecm work for my setup?
Old 03-17-2010 | 10:15 AM
88Trans-am's Avatar
ill probably grab those headers from you, but i will have to get them shipped if thats cool with you,PM me
Old 03-17-2010 | 05:59 PM
Car: 1989 IROC-Z
Engine: 346 LS6
yep, 1989 black on grey fully loaded 350, and yes 9 bolt 2.77 hahaha... ive since swaped out to a hybrid 8.8 ford with 3.73
sale pending on the headers
Old 03-18-2010 | 05:13 PM
Car: 1989 IROC-Z
Engine: 346 LS6
BUMP
Old 03-19-2010 | 07:09 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: 58mm TB, MAF, 083 heads, LT headers, 165 ECM, accel 30lbs inj.
rockers sold..... back to the top
Old 03-21-2010 | 11:57 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
headers shipped to 27529
Old 03-24-2010 | 07:46 PM
wbspoon's Avatar
Car: 90,94,96 C4, 93 F 07 K3500
Engine: L98, LT1
Transmission: M6
Are the heads unmodified? I have someone looking for a set that are still virgin and not cracked.
Old 03-24-2010 | 10:29 PM
Car: 1989 IROC-Z
Engine: 346 LS6
ya.. heads are totally stock and no cracks that i am aware of.. but i owned the car they were on and they were fine
still have stock valves,springs, and seals.. i can dissasemble if it was desired
Lee
Old 03-27-2010 | 03:08 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: bosch MAF, 083 heads, LT headers, 165 ECM, accel 30lbs inj.
BUMPITY
Old 03-27-2010 | 07:13 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
are you willing to separate the memcal from the ecu? If so, highly interested (just to be sure, the ecm is from a 350 L98 car, correct?)
Old 03-28-2010 | 07:05 PM
  #42
Car: 1989 IROC-Z
Engine: 346 LS6
i am selling only a 165 ecm it is out of my 1989 l98 iroc.... you are looking for a memcal from a 350?. i have a hypertech chip for 165 ecm 350 and the stock chip as well.
Old 03-28-2010 | 08:13 PM
  #43
HCR13's Avatar
Car: 1987 Trans Am
I'm just looking for the stock chip. I'm just trying to get the car running right. How much for the stock L98 chip shipped to 30907?
Old 03-30-2010 | 12:59 AM
  #44
inthe10s's Avatar
It's been a week should I have received the rockers already? I've never had anything shipped to me from Canada.
Old 04-13-2010 | 10:06 AM
  #45
IROCZ28KevinZ's Avatar
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
i am all over those heads if they are still avail and you are willing to ship to 65301 (missouri).
Old 04-14-2010 | 08:27 AM
  #46
101btp's Avatar
Car: 86 Trans am
still have that ignition system?
Old 04-15-2010 | 04:37 PM
  #47
88Trans-am's Avatar
do you have a prom that works for that intake and fuel injector system?
Old 04-15-2010 | 05:27 PM
  #48
Car: 1989 IROC-Z
Engine: 346 LS6
no i dont anymore, but i can tune if you get your car going and are interested.
Lee
Old 04-15-2010 | 07:56 PM
  #49
88Trans-am's Avatar
depends on what you would do it for, as getting the car to you would be a big issue as i do not have a trailer. I could pay for your gas to come down here. hit me back with a msg and maybe we can work something out, thanks
Old 04-16-2010 | 03:01 PM
  #50
jersyboyy's Avatar
Car: 85 Camaro
Hey you had longtubes for sale did you also have an exhaust to go with those long tubes by any chance?
Quick Reply: 083 heads, 165 ECM, accel 30lbs inj. crane hi6s igntion box
