16" aftermarket electric fan/ Derale electirc fan thermostat
I have a 16" aftermarket electric fan w/ Derale adjustable electric fan Thermostat. Baically you set the temp you want fan to turn on and off. You don't have to work about turn fans on and off with a toggle switch. I have the wiring diagram also. I had it on my Camaro and it never went over 195 on a hot day which is good considering mid 80's Camaro's tend too run hot. So on any other car it should never go over 180-185. I want $80 for the set up.Here are some pics:
