[MI] 350 SBC SuperRam and T56 driveline for sale
Old 01-21-2010 | 07:01 PM
88fb350's Avatar
Want a title? Post!
Car: 1988 Formula Firebird
Engine: 400cid single turbo
Transmission: T56 Viper
Axle/Gears: Strange 12 bolt 3.73
The following powertrain out of my 88 Firebird is for sale:
Engine *(SOLD)*
• 355 cid SBC – 4 bolt main
• TRW pistons, OEM crank and “Pink” rods
• Lingenfelter SuperRam intake & base – port matched plenum/runners
• Lingenfelter hydraulic roller cam (.525 lift / 219 duration)
• TFS aluminum 23 deg heads. (195cc 2.02/1.60 62cc chamber)
• Crane Cams aluminum rocker arms (1.5 ratio)
• Hamburger baffled oil pan with kick out
• Edelbrock Victor water pump
• 36 lb Bosch blue top injectors. Also OEM 24 lb injectors
• 305/T5 ECM with Lingenfelter chip for above cam and intake and OEM injectors
Exhaust *(SOLD)*
• SLP 1 3/4" 409 stainless headers
• SLP 3” 409 stainless intermediate pipe, muffler & twin tailpipes (driver side exit)
Transmission *(SOLD)*
• T56 6spd manual (2.97 1st gear) BW aftermarket replacement for T5
• Centerforce dual friction clutch (pn DF161056)
• Lakewood SFI bellhousing (pn 15020)
• OEM trans cross member, torque arm and propshaft modified for above
Approximately 10k miles.
Attached Thumbnails 350 SBC SuperRam and T56 driveline for sale-350sbc_sr2.jpg   350 SBC SuperRam and T56 driveline for sale-350sbc_sr3.jpg
Old 01-21-2010 | 07:12 PM
TommyG's Avatar
Car: Chevy
Transmission: 700R4 Automatic
Re: 350 SBC SuperRam and T56 driveline for sale
If you are parting out, How much 4 the Slp System how many miles any damage dent rust? Tommygunnem@yahoo.com pics Please!
Old 01-21-2010 | 08:39 PM
88fb350's Avatar
Want a title? Post!
PM and pics sent
Old 01-21-2010 | 08:53 PM
88fb350's Avatar
Want a title? Post!
sorry - email and pics sent
Old 01-21-2010 | 10:34 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
can I get some pics and price for the SLP Headers and y-pipe? I'll send a pm with my e-mail address.
Old 01-22-2010 | 09:36 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I'm interested in the trans
-jason
Old 01-22-2010 | 02:54 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Also interested in the headers and exhaust, please email hirspat@hotmail.com
Thank You
Old 01-22-2010 | 04:48 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Do you know how much HP the engine was putting out? My engine is pretty much identical.
I have 357, pink rods... etc
Lingenfelter Superram Set-up with bbk 52mm tb
Trick Flow AL heads, Gold Crane rockers... etc.
Old 01-22-2010 | 06:15 PM
88fb350's Avatar
Want a title? Post!
PM sent
Old 01-22-2010 | 06:32 PM
88fb350's Avatar
Want a title? Post!
-jason
The trans is the t56 replacement for the t5. About 8k miles on it along with the Centerforce Dual Friction clutch. The driveshaft and OEM torque arm are shortened to fit the t56's longer tailshaft. I'd like to sell the clutch and trans together (and SFI bell housing if possible). $1300 for the clutch and trans and $250 for the bell housing. Let me know if you would like some pics.
Old 01-22-2010 | 06:37 PM
88fb350's Avatar
Want a title? Post!
Thank You
email sent
Old 01-22-2010 | 06:44 PM
88fb350's Avatar
Want a title? Post!
Never dyno'd it but with street tires (BFG KD's) it ran 12.80s at 112mph with a 1.95 to 2.0 60 foot time. Rear axle ratio was 3.73. The car weighed ~3650 lbs with driver so its about 390 to 400 HP (calculated).
Old 01-22-2010 | 06:50 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
If you have no interest in the motor and are lookin to part....i would be interested in a few things. SR and heads...PM me a price.
Old 01-25-2010 | 09:52 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Price on headers and Y pipe? Is it sold?
Old 01-26-2010 | 07:01 PM
88fb350's Avatar
Want a title? Post!
Nope. Its still available. $400 for headers and Y pipe. $475 for the entire exhaust system as pictured.
Attached Thumbnails 350 SBC SuperRam and T56 driveline for sale-slp-3rd-gen-exhaust.jpg
Old 01-26-2010 | 07:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
would it be alot to ship the complete exhaust to 90650
Old 01-26-2010 | 07:53 PM
88fb350's Avatar
Want a title? Post!
Yeah - A quick look at UPS shipping calculator looks like about $240 to ship to your zip.
Most likely due to the large box size for the Y-pipe (its welded together)
Old 01-27-2010 | 05:17 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
does this trans includes hydraulics that fits SBC block ?
so it is T56 like LS1 has ?
best regards
Old 01-27-2010 | 11:00 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Im interested in the Lakewood SFI bellhousing if you are willing to sell it seperately???? Could i get the part number as well just to double check that it will work wit my set up. Thanks
Old 01-27-2010 | 11:31 AM
88fb350's Avatar
Want a title? Post!
best regards
Its like the LS1 T56 but is set up for use with the T5's throwout bearing, clutch fork and master/slave instead of the LS1 trans CSC arraignment. This T56 is the repacement unit for the T5 3rd gen fcar owner who wants to upgrade to the T56. The only mods needed are to modify the trans cross member and shorten the driveshaft and OEM torque arm. These items are included with the trans. You can also use the BMR or Spohn torque arm located off their cross member. Also included is the clutch fork. I'll check if I still have the master/slave.
Old 01-27-2010 | 11:36 AM
88fb350's Avatar
Want a title? Post!
Yep, will separate the bell housing. Its pn 15020.
http://www.summitracing.com/parts/LAK-15020/
Old 01-27-2010 | 11:49 AM
6SIX6's Avatar
Car: 89 IROC
What hydraulics are you running as that looks to b a T5 bellhousing???
Old 01-27-2010 | 12:19 PM
88fb350's Avatar
Want a title? Post!
I was running the T5 hydraulics. The aftermarket T56 trans I ran was the T5 replacement.
Old 01-27-2010 | 02:02 PM
6SIX6's Avatar
Car: 89 IROC
Wont work for me as I got T56 hydraulics. Oh well
Old 02-10-2010 | 09:29 PM
88fb350's Avatar
Want a title? Post!
Reduced pricing. See original post.
Old 02-13-2010 | 03:46 PM
69Cyclone's Avatar
Car: 1992 Trans AM GTA
Pm sent.
Old 03-01-2010 | 09:29 PM
88fb350's Avatar
Want a title? Post!
TX3
Old 03-01-2010 | 10:04 PM
1970 Buick's Avatar
Car: 1989 GTA
pm sent email is andy11678@gmail.com
Old 03-13-2010 | 08:49 AM
Great White's Avatar
Want a title? Post!
Car: 88 Corvette
Engine: ZZ4
Axle/Gears: 2.79
Is the superram intake and base still available, or the cam?
Old 03-14-2010 | 12:44 PM
88fb350's Avatar
Want a title? Post!
Yes, SR and cam are still available.
Old 03-19-2010 | 04:26 PM
rdsxfn524's Avatar
how much for the heads
Old 03-21-2010 | 09:13 AM
88fb350's Avatar
Want a title? Post!
PM sent
Old 03-21-2010 | 07:41 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
are the SLP headders sold?
Old 03-23-2010 | 01:00 PM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
i am interested in the whole motor looking to drop in a 1989 GTA would this drop in or be a pain. Thanks
Old 03-23-2010 | 09:38 PM
88fb350's Avatar
Want a title? Post!
Yes - headers were sold.
Old 03-23-2010 | 09:50 PM
88fb350's Avatar
Want a title? Post!
Since your 89 GTA is essentially the same mechanically as my 88 Formula it would be an easy drop-in swap. Your car uses a MAF too so the ECM prom may work as well.
Old 04-06-2010 | 02:35 AM
Cthornsmax92's Avatar
how much for the lingenfelter intake shipped to 33411
Old 04-06-2010 | 06:35 AM
Pat Hall's Avatar
PM sent...
Old 04-06-2010 | 09:11 PM
88fb350's Avatar
Want a title? Post!
PM sent.
Old 04-09-2010 | 01:01 AM
leoshotthirdgen's Avatar
Car: 91' RS
Engine: 383
Is tranny still available? If so how much for just tranny and driveshaft sent to 91977?
Old 04-09-2010 | 10:13 PM
88fb350's Avatar
Want a title? Post!
Sorry. Trans, bellhousing and driveshaft were sold.
Old 04-10-2010 | 03:54 AM
  #42
Hulkamania's Avatar
Car: 1988 Camaro Iroc Z
Engine: 5.7
Axle/Gears: 2.77
PM sent
Old 10-10-2011 | 10:50 AM
  #43
paterra's Avatar
Have you ever sold the superram? paterrachevy@yahoo.com
Old 10-10-2011 | 11:17 AM
  #44
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Originally Posted by paterra
Have you ever sold the superram? paterrachevy@yahoo.com or 661-718-7047
just a heads up, You might not want to post your email on the net like that. spam trolls search sites for adresses and numbers and you will get a nice inbasket full of spam as well as phone calls from telemarketers.
Old 10-11-2011 | 02:55 PM
  #45
paterra's Avatar
thanks for the heads up, i never realized that
Old 10-11-2011 | 08:45 PM
  #46
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
how much for super ram?
Old 10-11-2011 | 08:52 PM
  #47
88fb350's Avatar
Want a title? Post!
Yes, it was sold.
Old 10-11-2011 | 11:18 PM
  #48
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
ever sold cam and springs??
Old 10-12-2011 | 04:12 PM
  #49
88fb350's Avatar
Want a title? Post!
Yes, the complete engine with SR was sold.
Mickeyruder
09-02-2015 03:45 PM
BlackphantomZ28
08-31-2015 11:29 AM
86White_T/A305
08-17-2015 01:16 AM
sreZ28
08-14-2015 08:48 PM
BBSDesigns
08-11-2015 08:39 PM
