[Sold] PBR rear brake kit COMPLETE
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
I have a full pbr rear disk swap kit off my 92 Z28. Was in great shape when removed, just decided to go with the LS1 rear setup since i already had all the parts. The rotors are slotted and dimpled and have maybe 500 miles on them. The pads are bendix and also have the same mileage. One of the calipers is also new and has that mileage. The rotors are painted as well as the calipers. The backing plates will work on both 10 bolt rear ends and 9 bolt rear ends. I had this on both rear ends myself, i just elongated the holes and it worked great with both. Included everything pictured, with e brake cables, equalizer, pads, rotors, calipers, caliper brackets, backing plates, and all bolts. These kits sell of 800 new.
Asking $300 shipped
Asking $300 shipped
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: PBR rear brake kit COMPLETE
what size are those rotors? also what is that "equalizer" you mention?
thanks
thanks
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
1992 Trans Am
08-08-2015 08:16 PM
