[NH] TH350 short tail, Ratchet shifter
TGO Supporter/Moderator
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
These are parts that came out of a second gen I bought. I had intended on using the trans on my Z28, however I have since opted to run a manual.
The trans is a Th350, short tail shaft. It was rebuilt a few years ago, and installed in an '80 behind a 358 making maybe 300hp.. The guy I bought the car from says he ran it about 2500 miles. Based on the oil leak (dizzy, valve covers) I thought he was full of it but when I yanked the heads off I realized that it's probably more true than not. The inside of the motor was absolutely amazing, no wear, fresh hone marks, zero carbon.
Anyhow.. I tested the trans around the yard. Seems good. $250 for local pickup.
Next, I have a hurst Vmatic ratchet shifter. This is set up to fit in a 2nd gen console, but you could probably make it work anyhow. $100 plus shipping.
-- Joe
-- Joe
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: TH350 short tail, Ratchet shifter
Do you still have this shifter?
Car: 91 rs
Transmission: th350
Do you have the console that the shifter origanally came with? I am wanting to put it in a truck and would like to have that.
-- Joe
Car: 91 rs
Transmission: th350
I was not reffering to the camaro console, but the little one for floor mounting the shifter, like. If this was origanally meant for a camaro console it may not have come with one, are you familiar with what I am talking about?
-- Joe
TTT. I keep tripping over the trans. Someone must want it for their strip car.
-- Joe
-- Joe
trans sold.
