[FL] My fully built shortblock built by dennis jones
I am selling my complete bottom end as I have come across a different build.
It was built by one of the best motor builders in central florida. He does the motor work and head porting for the fastest cars here in florida. very creidble man.
The block is a 350 4 bolt main bored .030 over that was brand new before me. It has 5k on it since I built it and has had its oil changed every 1500-2000 miles.
The block has beenbored with torque plates line honeds square decked oil lines tapped and plugged arp main bolts.
The internals start with a eagle crank and rods that are good for 900hp.
Also used arp bolts on the rods.
The piston are forged keith black pistons the black series which are 500 dollar pistons. Good for a 200-250 shot on top of what you are running on motor.
with 64 cc heads its 11:1 compression.
I used seal pro rings for the pistons and are gapped for a 200-250 shot.
I used King bearings which are heavy duty for nitrous also and anything u might throw at it.
I have receipts for everything and can show you it cost more than 4500-5000 dollars to build a nice shortblock like this with parts machine work and labor.
I am selling this for 3500 OBO. I will back it up to the point of machine work and what I listed it to the full extent.
This motor will Last you the test of time. I will sell the motor with the current cam and roller lifters and hyrda rev kit and push rods for 4250 OBO.
I will post pics when I get home of everything on this block. I can also have a video clip of it.
I will part out but only if at least 75% of it sells
skinny z
10-05-2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
