22LB GM/ROCHESTER Injectors
This last weekend I was scouring the local pull a part and came accross a tuned port setup in an 87 Formula 350. I brought the injectors into work to clean and flow them. To my surprise all 8 flowed very good so I decided I would put them up for sell otherwise they would have went right in the trash.
From what I can find on this part # 5235302, they are standard on 350's from 87-88 and they flow 21.6lbs/hr so I figure they are 22lbers. I am guessing these have pretty low mileage because they flow so good and the engine was surprisingly clean when I pulled the intake off.
I'm looking for $75 shipped on these, but I am open to offers.
Re: 22LB GM/ROCHESTER Injectors
Just thought I'd chime in and let you know your info is correct on those injectors. I have a full set of them that I had Rich at Cruzin Performance clean and flow match. As far as stock injectors go, these are FAR better than the POS Multecs GM started using around 89. I also like how they have a nice aluminum tip on the nozzle instead of brittle plastic. $75 is a good deal for a well working, low mileage set. P.S. They're Rochester brand, but manufactured by Bosch.
Car: 90 chevy camaro convertible iroc
Engine: 305 tpi
Transmission: 700r4 with hurst dual gate shifter
hey have a pic of them all and might be interested
thejimsterz28
09-15-2015 04:37 PM
