[NJ] 350sbc crankshaft, rods, pistons(.060over)
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Have a set of pistons, rods, and a crankshaft from a stock 350sbc. everything is fresh! the motor these parts came out of was recently rebuilt. these parts have no miles on them or run time since they were freshend up. pistons are cast aluminum w/ a dish to them. dont know much about them.
askin only $150 for everything.
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: 350sbc crankshaft, rods, pistons(.060over)
still have fs ?
any info on pistons?
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yes still forsale and the pistons are cast aluminum and .060 over. other then that i dont have much info.
I need to pressure check the block i have and then if it will need boring.
It's 30 over now, I'm hoping to replace the 30 over pistons only.
You don't have a 30 set up do you....lol
Its a rebuild for a 78 truck that I will sell with a fresh motor.
but with you set up it may be less to bore, that doing the rod and crank.
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
is the crank a 2pc rear main or a 1? and how much for just the crank and could i get pics of it? thanks Ty.
Car: 1989 Camaro RS
Engine: LO5 350
nevermind on the pics, i was at work when i saw this and the pictures didnt load
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Tyrel2018 the crank is a 2piece rear main seal.
Well if Tyrel2018 wants the crank and joeEZ wants the pistons and rods. I'll Split the price equally and the price of shipping.
I can totally do that if thats agreeable with you guys?
$75 for pistons and rods plus shippin
$75 for crank and shippin
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres the numbers off the crank
3932442
5K
ET28 or E128
those are all the numbers on the crank that my be important
3932442
5K
ET28 or E128
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
