[VA] TPI injection/harness/ecm package. And 113 aluminum heads
Car: 94 Vette 91 Formula
Engine: LT1, L98,
Transmission: MX0
Axle/Gears: Dana 44 3:45
Complete TPI system off of an 88 Corvette. You get the plenum, both runners (no dents) Intake manifold, throttle body, fuel rails, injectors (you should really get new injectors cause who knows), dist cover, fuel pressure reg, egr, all attached sensors, Engine harness, ecm. Basically just needs a MAF sensor.
499.00 plus ship about 35.00 unless you live way out. Or pick up from 20164 or 20111.
Also Off same car is a set of aluminum 113 heads. 350 plus 40 ship.
Sanjay
08-12-2015 03:41 PM
