[NC] 350 lt1 out of a 93 z28
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I bought a lt1 motor out of a 93 camaro from a friend. it had 100k on it and only had a small tick. well io tore it down and found 1 bent rod. I since then got a new motor. So i dont need this stuff anymore. I stripped the heads cleaned them and glass beaded them. They are aluminum obviously. I have the cam, crank, exh manifolds, oil pan, oil pump, block 2bolt, timing gear and chain, i even have a flex plate. im gonna keep the intake but im gonna sell the throttle body and injectors.It has new roller lifters because the guy before me thought the tick was from a bad lifter. if you have any questions send me a message. I have pics but idk how to post them on here just give me an email and i can send them that way.
Car: 92 Camaro RS
Re: 350 lt1 out of a 93 z28
all is still for sale. I want 600 for the whole motor setup. any takers?
