[MO] Patriot Performance 190cc Aluminum heads brand new
I decided to scrap my rebuild and I bought a LS1...got a smoking deal. So Im going to part the rest out.
I have a brand new pair of Patriot Performance Freedom 190cc 2180 angle plug aluminum heads for sale. Bought them back in April from Summit mocked them up on the motor and never bolted them down. Specs are below.
Combustion Chamber: 64cc
Intake Runner: 190cc
Exhaust Runner: 62cc
Intake Valve: 2.02"
Exhaust Valve: 1.60"
Max. Valve Spring Lift: 0.575"
Spring Pressure Closed: 115 lbs. @ 1.800"
Spring Pressure Open: 310 lbs. @ 1.225"
Retainer Material: Steel
Valve Seal Material: Viton Valve Guide
Material: Manganese Bronze
Valve Job: 5-angle
Screw in 3/8 studs
guideplates
$650 shipped in the lower 48 US.
Intake Valve: 2.02"
Valve Job: 5-angle
Screw in 3/8 studs
guideplates
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Patriot Performance 190cc Aluminum heads brand new
Located?
Re: [MO] Patriot Performance 190cc Aluminum heads brand new
Hey
How much you wanting for the heads now.Will these heads work
with a stock tpi sytem? Will it bolt up i mean? My tpi has been ported.
Thanks Matt
Thanks Matt
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Dang Im was hopeing he was going to say "back up for sale"
Now that I got the cash i was going to jump on them!
ambainb
04-25-2016 09:21 PM
