GM Performance Parts ZZ4 350 for sale (new price)
Up for sale is my ZZ4 350 crate motor. It has approx. 11,000 miles on it. I recently pulled it out of my 1985 Z-28 which I just sold. Last time it was run was beginning of June. It is painted Chevy orange w/ aluminum heads. It also has polished aluminum (tall) valve covers, polished breather and PCV, polished aluminum water pump, chrome alternator,polished brackets and polished swivel water neck.It also has an aluminum GM Bowtie intake on it and a brand new Holley Street Avenger 670cfm carb. When motor was in my Camaro it was dyno tuned by Berrel Automotive aka The Injection Connection (Located in Horsham,Pa) . It was dynoed @ 293 HP to the rear wheels which is approximately 360HP @ the flywheel. I have the reciept and dyno sheet to prove. Motor is complete from carb to pan. For a couple of dollars more I will throw in a Summit Racing Street&Strip MSD Ignition box (which the distributor is already set up for) and also a Chrome 14" Summit Racing air cleaner w/ K+N air filter. Motor runs perfect. There isn't anything you have to do except install it in your car and turn the key. Depending on what you put it in you should have a consistent mid 13-high 12 second car/truck. Motor is already out of the car . I have 2 videos which are listed below of the motor in my Camaro. Asking $3000 B/O
Located in Hatboro,Pa
Specs of motor:
http://www.gmperformanceparts.com/En...9712&engCat=sb
Specs of motor:
