[VA] Corvette 113 Auminum heads and TPI system.
Car: 94 Vette 91 Formula
Engine: LT1, L98,
Transmission: MX0
Axle/Gears: Dana 44 3:45
All off a running 89 Corvette.
113 aluminum L98 heads, great for upgrading your iron heads. Will work on any small block pre LTx motor.
good valves, springs, comes with head bolts (you should really get new ones though) rockers, stud nuts/washers.
300.00 pick up or 360.00 shipped.
TPI set up, comes with intake manifold, throttle body, plenum, runners (no dents which is a miracle), fuel rails with injectors (no guarantee on injectors) and whatever sensors are attached.
299.00 pick up or 344.00 shipped
Car: 1988 iroc z
Engine: 350 tpi
Re: Corvette 113 Auminum heads and TPI system.
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
pm'd about the heads and tpi setup a while ago... just wondering if they're still available
Sanjay
08-12-2015 03:41 PM
