[IN] Holley Stealth Ram Intake Manifold
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
I HAVE A 1YEAR OLD USED SATIN FINISHED HOLLEY STEALTH RAM INTAKE MANIFOLD FOR SMALL BLOCK CHEVY. http://www.summitracing.com/parts/WND-7540/ WAS USED ON A TUNED PORT 383. LESS THAN 3000 MILES ON INTAKE.ALSO HAVE THROTTLE BODY, WITH AIR FOIL, TPS SENSOR,AND IAC., DISTRIBUTOR, AND COIL MSD.
Horsepower from idle to 6,500 rpm.
These Weiand Stealth Ram EFI intake manifolds have the tuned port looks that you want with the high-flow capabilities that you need. They feature 2-piece designs with short individual runners and a larger upper plenum. With D-shaped runners, these intakes promote high flow rates without turbulence. That makes the Weiand Stealth Ram EFI intake manifolds the perfect choice for your street/strip vehicle.
ALSO HAVE MATCHING DISTRIBUTOR, AND COIL MSD.
UPPER AND LOWER INTAKE = $250.00
UPPER AND LOWER INTAKE, THROTTLE BODY, DISTRIBUTOR, AND COIL = $300.00
James 317-752-7406
THANKS
James 317-752-7406
THANKS
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: Holley Stealth Ram Intake Manifold
If it's not sold I will take it for $300 shipped.
Let me know,
Thanks!
Let me know,
Thanks!
275 plus shipping for upper and lower intake, mounting hardware, throttle body with airfoil.
9192camaro
16
02-03-2019 12:21 AM
86IROC112
08-17-2015 02:00 PM
L98GTA87
08-11-2015 06:55 PM
