[NY] WC-T5, nonWC-T5, 4-bolt 350 complete and more
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
PICTURES ADDED TO BOTTOM
- WC-T5 setup, 3k on rebuild, shifts perfectly, no grinding, B&M shifter, bellhousing, clutch fork, clutch (5k on new clutch/pressure plate), master/slave cylinders, throwout bearing (still in car, swapping in T56 in 2 weeks, will be removed then), pick-up/meet, Make offer
- nonWC-T5, gears 1-4 work perfectly, won't go into 5th, was driving along and went to shift into 5th, wouldn't go, nothing exploded, no grinding, includes bellhousing and clutch fork, may have a T/O bearing as well, comes with stock shifter, pick-up/meet, Make offer
- Complete 4-bolt crate 350 engine, approximately 30k miles, runs strong, took my Camaro to a best time of 9.51 in the 1/8th at 76mph. Uses some oil due to bad valve seal on cylinder 6, otherwise in great running order. Don't know specs of engine, includes Edelbrock Performer intake with carb adapter/spacer. $600 obo picked up
- LT1 flywheel, nice condition, needs to be resurfaced, $80 shipped
- T/A Firebird dash map pouch, nice shape, $15 shipped
- Stock rear lower control arms, pick-up, $10
- Stock steel driveshaft, pick-up, $20
Car: 1986 IROC-Z
Re: WC-T5, nonWC-T5, bellhousings, control arms, LOTS MORE!
I know someone wants a nice, freshly rebuilt World Class T5 swap...
Car: 1986 IROC-Z
Pictures:
Car: 1986 IROC-Z
bump
Car: 87 Firebird Formula, 97' GMC Sierra
Engine: LT1, 4.3 Vortec
Transmission: T-56, 4L60E
Axle/Gears: 4.10 Posi, 3.42 Posi
How much you lookin to get for the WC setup?
Car: 1992 camaro rs
Transmission: t5
Do you have a master/slave hydraulic assembly availble as of now?
Car: 1986 IROC-Z
I'll send you a pm.
Sorry, the only setup I have is in the car. If it doesn't go with the setup, then I'll have it available. I'll let you know.
1 Post
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
do you still have either of the t-5's?
Car: 1986 IROC-Z
I actually still have them both. Let me know what you need.
Car: 1991 1LE CAMARO
Engine: L98/355cu
Transmission: WCT5/for now
Axle/Gears: 9 inch ford/ detroit locker
I need a wc t5 to replace my broken one how much are you wanting for your set up? thanks Bryan
Car: 1986 IROC-Z
I have the following parts available from the WC-T5 setup ready for pickup today: WC-T5 transmission, B&M shifter, bellhousing, clutch disc, pressure plate, flywheel, throwout bearing, mounting hardware. The hydraulics are shot and cannot be used.
I also still have the non-WC T5 and much of the parts in the list above.
WC-T5 setup: $500
non-WC setup: $250
I would prefer these to be picked up. Shipping is a real pain...
WC-T5 setup: $500
non-WC setup: $250
Car: 91 camaro RS
Transmission: t-5
how much for the WC t-5 i don't need the bell housing or pressure plate and anything just the trans shipped to 49001 Kalamazoo MI i would have no problem pay for the shipping if the price is rite
Car: 1986 IROC-Z
If I don't get someone that will offer to pick this up soon, I will consider shipping, but I really would prefer not to.
Car: 1986 IROC-Z
bump!
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
how much for just a bellhousing shipped to 16508?
Car: 1986 IROC-Z
MORE ITEMS ADDED INCLUDING 350 ENGINE COMPLETE
Last chance for the complete setups before I split these up. I have interest in part-outs.
More pictures:
WC-T5 with B&M shifter
non-WC T5 with stock shifter
Stock clutch disc, flywheel, pressure plate, also LT1 flywheel pictured
350 Engine
More pictures:
350 Engine
Car: 1986 IROC-Z
Somebody needs a perfect transmission or an engine, I know it!
Car: 1986 IROC-Z
WC-T5 sold pending payment on ebay.
Clutch, pressure plate, flywheel all sold.
1 bellhousing sold.
still have a bellhousing, non-wc t5, B&M shifter, and complete 350 engine.
1 bellhousing sold.
Terrell351
06-13-2021 01:13 PM
Chuck84TA
07-15-2016 09:05 PM
Eric-86sc
08-24-2015 09:01 PM
