26 Spline GM Axles Camaro Z28 82-92 7 5/8 10 bolt
Car: 87 Camaro
Engine: 5.7 350 TPI
i have a 26 Spline GM Axle from an 87 Camaro 5/8 10 bolt. It was from a rear with the drum breaks but im sure you could probably use it with other brake set ups.
Axle Splines: 26
Axle Length (in): 30.313 in.
Axle Type: C-Clip
Axle Material: steel
Wheel Stud Pattern: 5 x 4.75 in.
it is used and had no problems when on car. any questions feel free to ask
$70 shipped anywhere canada might be out of the question.
I am only selling one even though there are 2 pictured
Axle Splines: 26
Axle Type: C-Clip
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: round ones "3.73"
Re: 26 Spline GM Axles Camaro Z28 82-92 7 5/8 10 bolt
26 spline axles are best when thrown in the garbage!
1 Post
Car: 1990
Axle/Gears: stock
you may be right but if you already have them and you need one its good to know there is someone from a group you can trust with a reasonable price then its all good.
lets face it everything we have to use is decades old - and maybe you dont want to swap out the entire rear end.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
red90IROCls1
08-25-2015 06:56 AM
