[TN] FS: Innovative Motor Sports LC-1 Wideband Controller, O2, and DB Gauge (Red) - $200
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
SOLD!!!
Hey guys...
I'm selling my Innovative Motorsports Wideband O2 Controller, Wideband Oxygen Sensor and DB gauge kit.
The setup was installed in the car, driven 50 miles, and that's it. It's in like new condition.
I am getting a Holley Commander 950 w/ their wideband controller so I no longer need this LC-1 setup.
Innovative is running a special for this kit right now for $229 plus shipping. Normally a $289 kit. I'm willing to part with mine for $200 plus shipping.
The kit is still installed in the car, but I can remove it quickly if it sells. I'm probably going to un-install it this weekend anyways.
Here is a link to the kit with description etc.
http://www.innovatemotorsports.com/x...cat=262&page=1
Hey guys...
1 Post
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: FS: Innovative Motor Sports LC-1 Wideband Controller, O2, and DB Gauge (Red) - $2
I have been looking at the Innovate LM-1 to tune my carbed motor. I really want to be able to record a/f ratio and RPMs at the same time. Also view in live time and be able to view on the computer. Can the LC-1 do all this?
Car: 1989 Trans Am
Engine: 355 HSR
The LC-1 itself will not record A/F ratio at the same time. However when paired with an SSI-4 Simple Signal Interface from Innovative (which I also have available for sale) you can have all of them logged by the Innovative software.
The LC-1 is daisy chained into the SSI-4 to supply the Wideband signal. The SSI-4 has 4 signal inputs that can be programmed in. You can use it for RPM, TPS position as well as a few other items. Can't remember off the top of my head. It will log all of those items that you supply into the SSI-4 and LC-1 into one location. That's why I ended up getting the SSI-4. I just never ended up using the SSI-4. It was installed and the car never ran b/c I didn't get enough time.
Here is a link to info about the SSI-4:
http://www.innovatemotorsports.com/products/ssi_4.php
Like I said, I have an SSI-4 for sale as well. I can sell you the LC-1 controller, gauge, DB gauge and SSI-4 for $320 shipped.
Innovative Motorsports offers just the LC-1 and SSI-4 combo for $299, but that is WITHOUT the gauge. You are basically getting the gauge for $20.
Car: 1989 Trans Am
Engine: 355 HSR
Also -- read the links in the SSI-4 link I provided. It shows you how the LC-1 and SSI-4 are integrated to provide you what you need in terms of RPM and A/F.
Car: 1989 Trans Am
Engine: 355 HSR
Part is sold locally...
HoosierinWA
10-07-2015 10:15 AM
Dragonsys
09-25-2015 03:51 PM
950, commander, controller, db, diagram, fs, gauge, innovate, innovation, innovative, lc1, motorsports, o2, wideband, wiring
