Started 350 engine swap, got lots of SBC parts for sale
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Bought a 350 engine from a local yard to use in my engine swap. Came with lots of aftermarket parts installed and since im using a Vortec setup i dont need any/ or all of these parts. Prices are negotiable and shipping is included. Will have pics up later today.
Morso perimeter bolt valve covers (were chrome but were badly pitted, wire wheel cleaned them, and painted them flat black with high heat paint) $20 shipped.
EdelBrock Performer Carb Intake Manifold (cleaned and repainted Aluminum) $65 shipped
SBC Longtube headers (not sure on brand, rusty and need cleaning and painting. Not sure what vehicles they will work on) $30 shipped
V Belt Accessories (Water Pump, Power Steering Pump, Alternator. Fan is destroyed, will detach from water pump before selling.) $25 shipped for all of it (SOLD)
Stock GM Cast Iron heads for SBC. Casting number on heads is: GM354434. Come and get them and they are yours. No Shipping unless buyer arranges it.
I also have an Edelbrock Carburator. Electric Choke. It looks to be Performer Series. Probably needs a rebuild. Serial number on side is: 8822. If you can find some info on it such a CFM and model let me know. Will sell for $45 shipped. (SOLD)
Also have a spare air dam spoiler for any 82-92 Trans Am. Goes under front bumper to force air into radiator. Has 1 broken tab on very front point, will take $10 shipped for it. (SOLD)
Like i said i will have pics up later today. PM me with any questions you may have. Located in 49331, Michigan. I accept PayPal.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Re: Started 350 engine swap, got lots of SBC parts for sale
Do you have pics & a part number for the manifold?
thx
thx
Engine: Vortec 357
Engine: Vortec 357
89 IROC- got the part # off the manifold. Its 2101. Let me know if your still interetsed.
Engine: Vortec 357
bump for the day
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
FYI that manifold does have an egr provision, it has the block off plate on it in the pic..
got a pic of that air dam?
Car: 1989 IROC Z28
I believe that's a heat riser for an automatic choke. The 2101 Performer doesn't come w/ the EGR provision. Edelbrock Performer 2101
Still a very nice manifold for the money.
Engine: Vortec 357
sales pending on carb and v belt setup.
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Will the headers work on a 89 305 Camaro? Also do they have the o2 hole?
Car: 85 Z28 t-top/86 IROC t-top
Transmission: automatic
ok, the Carb is sold ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
you have a PM
you have a PM
Engine: Vortec 357
No 02 hole drilled in them since the engine came out of a 70's impala. Can have the bunge hole drilled for cheap. They may fit your car but may need some customizing. I can see if they fit my T/a when i pull the motor out tonite.
Engine: Vortec 357
bump for the day, pulled the 305 TBI engine out of my T/A yesterday. Engine is complete minus serpintine belt setup. PM Me with any parts you need off the engine. I have an aftermarket Holley 670CFM TB unit with AFPR on it that im willing to sell as well as the stock TB but it needs retapping of the threads in the back for the fuel fittings.
Car: 1984 Firebird
Axle/Gears: 4.10
is that the lower piece of the air dam that curves back towards the wheel well? or just the center upper piece?
never got a pm or pic
Engine: Vortec 357
its the peice that goes from wheel well to wheel well
Engine: Vortec 357
Engine: Vortec 357
bump... need this stuff gone, got no room for it. make me an offer on what you need. Willing to even trade for some parts i may need for my swap.....
1 Post
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
how was the compressor you pulled off the car? did it still work and have no leaks when pulled? may be interested...
Engine: Vortec 357
When i bought the car, the previous owner said they never hooked the a/c back up after rebuilding the engine. lines had some pressure but i never bothered to look into the a/c not working since its a t top car. If you know of a way to test to see if the compressor is any good with it off the car i can test it for you and let you know.
1 Post
i can't think of a way. the one on my TA is bad, it leaks out all the refrigerant. any pics and a price on yours?
Engine: Vortec 357
Ill get some pics of it tonite when i go to drop off my transmission. Hows $50 shipped sound?
1 Post
not bad, post up a pic or two and i'll let you know then, thanks
Engine: Vortec 357
Ok guys, I need this stuff gone so make me an offer on any of these parts and most likely they will be yours.
Engine: Vortec 357
So far the carb, v belt setup, and air damn have sold. I also have an Autometer 2 1/16" short sweep fuel gauge for sale. I will keep updating with parts, i also have an 89" formula T-5 305TPI that im parting as well.
Got my carb today ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
its a 1405 which is manual choke 600cfm
needs rebuilt but is in great shape
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Engine: Vortec 357
it is alwats on the front lefthand corner of the mounting flange on the edelbrocks and carters. I just had to wire brush it some read the numbers.
the 1405 had the manual choke so this one had the electric choke add on
#42
it is always on the front left hand corner of the mounting flange on the edelbrocks and carters. I just had to wire brush it some read the numbers.
#43
Engine: Vortec 357
all the better for you then haha.. and it seems i may not of just bought a stock 350 like i thought as each piston has 4.0280 penciled on the bottom of each piston which leads me to believe it has been bored. But by how much im not exact. But it needs rehoning as theres some scoring on the cylinder walls.
#47
Engine: Vortec 357
ill take a look for ya and let ya know.
theshackle
03-05-2017 06:37 PM
