[NJ] TBI and TPI Harness Pig Tails Sensors ESC IAC
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
i have 2 junk harness's that i cut up, one from TBI and one from TPI. i have just about every sensor harness with as much wiring attached as possible. lemme know what ud like!
also i have a few ESC modules for $30 shipped each
***SOLD***TPI TPS sensor harness, clip broken $5
***SOLD***TPI IAC harness, $10
TBI injector harness, for both injectors, $15
Camaro Positive battery cable, $15
TPI wires to starter, $15
TPI Dual Fan Harness w/ Relay, $50
TBI ECM thru firewall harness, $10
TPI/TBI air pump harness, $10
2 ESC harness's, $10 each
90-92 harness with wires to windshield washer pump, Power Steering pump and Charcoal canister, $15
TPI wiring to auto trans, $10
TPI/TBI 87+ alternator wires, $10
TPI/TBI ECM fuse holder and wires, $10
all prices include shipping
Re: TBI and TPI Harness Pig Tails Sensors ESC IAC
ttt
ok lemme go grab those, ill send u a PM in a little bit. i might have a tv cable, but its from a TBI motor
repliedddd
Car: 1990 Camaro RS
Transmission: automatic
do i need to swap out my esc module when i swap out my Lo3 to an L31.
If so is your esc module one for a 350, if so ill take it.
yes u should, however i have 2 from 305 motors aka LO3
bump
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
I don't suppose you have the injector wiring for TPI? Thanks
sorry no i dont
bumppp
yes, wat else were you looking for
bumppppppp
up topp
up
Car: 1987 Trans Am GTA
Axle/Gears: 3.73's
I'm in need of a TPS sensor and a mass air meter for my '87 TPI.. Do you have either?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I need the wire (2 pigtails with 2 connections on each side) that goes from the dizzy ignition module to the coil and the fuel pump relay pigtail. You wouldn't have those by any chance would you?
yes, ill check the # of pins and get back to u.... sorry 28 pins on mine, 12 and 16
bumppp
R3500
08-17-2015 12:16 PM
Sanjay
08-12-2015 03:41 PM
