408 SBC, heads, cams, rockers, serpentine setup
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Everthing OBO and +shipping. I will entertain any serious offer!
$575 Ported Pro-topline 180’s
Less than 10k miles since professional port work and valve job 280/202 cfm at .6 lift. Springs set up for 135lb seat pressure so good for flat tappet or roller hydraulic lifters. The are not pro-comps or some other Chinese casting. The iron heads never had the problems the aluminum ones did. Will include the once used head bolts and +.100 chromoly pushrods. SOLD
$750 408 short block .040 over block, eagle crank, ohio crank 4340 rods, Ross -20cc pistons. Motor has less than 10k miles on it. Main bearings are shot, but I caught it right away. Original hone is visible, just needs cleaned, crank polished and then new bearings and rings.
$100 Serpentine acessories and brackets for thirdgen. Underdrive crank pulley, polished alternator(was a reman before I polished by hand, not a cheapo chrome unit) water pump has been replaced as well.SOLD
$20 SBC Stock starter for 158 tooth flywheel
$50 Mini Starter unsure of brand SOLD
$80 Cam Motion Blower/EFI Nitrous Grind Cam 235/245 @ .050 .495/.507 on 112LSA. With marked flat tappet lifters.
$50 stock lt1 cam, lifters, springs, pushrods, rockers. SOLD
$50 16x Trickflow Chromoly pushrods 3/8 7.900" length should be +.100 for a SBC, half used for test fitment, half ran for less than 5k miles SOLD
$25 8x 7.900 3/8" pushrods less than 10k miles SOLD
$25 8x 8.000 3/8" pushrods less than 5k miles SOLD
$25 valve stud Girdle for a SBC SOLD
$130 for all or make offer, all come with poly-locks SOLD
8x 1.5 Crane Gold roller rockers, worn
8x 1.5 Lunati roller rockers same as crane's just blue
8x 1.6 Crane gold roller rockers
Axle/Gears: 3.70
Re: 408 SBC, heads, cams, rockers, serpentine setup
2.02/1.6 the heads are 180cc intakes, they've got some port work in the bowls and port matched to a 1205. Very good flow for the size of runner. The combustion chambers are 64cc.
Also, not sure if I have 24x poly locks for the rockers or just 16.
Axle/Gears: 3.70
TTT, I've had some interest in some parts, but nothing but the LT1 cam has sold. Feel free to make an offer.
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
Serpentine acessories and brackets shipped to 32907 and does it come with the powere steering pump also?
Car: 1992 Firebird
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
PM me regarding the heads please.
evilstuie
01-09-2020 08:29 PM
Mickeyruder
09-02-2015 02:45 PM
