F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e
Old 12-01-2008 | 08:55 PM
HuggerI-ROC's Avatar
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
PLEASE read what’s included before asking me if it is or not.
I have listed all parts you will need to have a fully running engine also.
Engine Parts
The wiring harness was modified by me(3rd time I’ve done this) and is now a fully stand alone harness, all unnecessary wires have been removed. All hook-up wires are fully label for an easy install. Also has wires installed for aftermarket oil pressure and water temp gauges. Will neatly wrap after sell.
I can, for the buyer:
Delete A/C and all wires associated.
Turn the harness into an “Automatic Transmission” harness
Computer, per buyer’s request:
Remove VATS
Remove rear O2s
Set “on” fan temp
Retune computer for an automatic
I am looking to get my moneys worth for this set-up/time and parts put into it
And also a local buyer – I will start my price at $1950 obo
Any OTHER question anyone needs answering, there is PM’s and my cell at 281-413-4582
I am located in Cypress TX 77429
Shipping: Can/Will Ship at buyers expense, Send me a zip and all send you a quote. Well be shipped with the oil pan in the picture but it is in no way usable.
Will separate if I have a buyer for each/every thing.
Included:
2000 engine block w/ 86k from a Firebird Formula
Installed 2002 241 vette heads with valve job, new seals, installed with all new bolts and metal head gaskets
2000 modified wiring harness
2000 stock computer (currently for manual trans)
2002 Low mile 18K stock springs and rockers
Installed New GM high performance lifters
New LS2 water pump with gaskets
Installed New LS6 oil pump
Installed New LS2 timing sprockets and chain
Starter
Stock balancer pulley
Valve covers
Alt bracket
A/C bracket
P/S pump bracket
Oil pickup tube and tray
Coil packs and brackets
Stock spark plug wires
NGK TR55 Spark plugs
Stock Fuel lines
Stock Injectors
LS1 intake
LS1 Steam crossover pipe
LS1 Throttle body and sensors
Two O2 sensors
EGR block off plate
Cam, thermostat, oil level sensors
Bolts bolt bolts
All the parts you will need to make it run:
Pushrods
Injector ring seals
PCV tubes
Oil pan
Alternator
P/S pump, A/C compressor
The converter only has about 4000 miles and is in perfect working order.
Is a Yank Super Stock 3600 stall, single disk.
Temps never got above 180 in my tranny.
I will post pictures soon.
Looking to get $540 shipped OBO and I can include flexplate if needed.
I also have a 4L60e that needs to be rebuilt, has a transgo shift kit installed.
Transmission slipped once on a pull and lost 3rd or 4th gear.
I will include with in a Yanks SS 3600 stall ($750 new), flexplate, Shifter, Shifter cable.
Asking $650 all of it or $600 with motor.
Other Parts I can also provide:
3" in/out flowmaster y pipe
Dynomax welded race muffler 3" in/out
Autometer C2 gauges: tach, speedo, fuel, oil pressure, water temp.
Trades welcome, looking for 99 TA LS1 parts:
Double adjustable LCA
subframe connectors
spec stage 3 clutch
spec flywheel
Also like laptops and digital camcorders
Cheers, JR
Attached Thumbnails F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-engine-side.jpg   F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-parts.jpg   F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-harness.jpg
Old 12-05-2008 | 07:34 AM
Re: F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e
TTTOP
Old 12-12-2008 | 02:00 PM
No one interested in a ls1 motor? lol wow.
TTT
Old 12-12-2008 | 04:01 PM
LS6_IROC's Avatar
would you ship to Canada?
Old 12-23-2008 | 01:40 AM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
nothing yet man??
Old 12-23-2008 | 04:20 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
im very intersested but your in texas and everyones broke from buying christmas gifts lol. if you hold onto if for about a month are two im sure itll blow up with offers once the season has passed. if you dont get rid of it soon whats a shipping quote too 62294 IL
Old 12-23-2008 | 07:00 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
how much for just the ls1 longblock? thanks
meeklay812
10-01-2015 04:46 PM
dusterbd
09-29-2015 09:40 AM
