200r4 ... 292 cam with lifters Lower delaware plus lots other parts
Want a title? Post!
good 200r4 came from a 1986 olds cutlass it has dual bolt pattern with stock converter, shifted good $ 150 I prefer not to ship this.
Also have a 292 comp cam with hyd lifters. $ 75 ... 100 shipped to lower 48...
3500 stall tci about 100 miles went to 3500 with anti balloon plates. 150.
Griffen rad aluminum universal fit about 27" accross. 125.
305 bare block. $75 obo
400 bare block 2 bolt ready to go. it has a sleeve in #6 cylinder professional done. $150.
all line honed. over 800 into block.
700r4 for a 4x4 will not shift from second to third . was had been mod to hold extra clutches and shift better. might be something simple. went to th350. $100
driver side floor pan for 67 Camaro full length. $25.
2 sets of crager ss. need to be redone . make an offer for set some has good tires.
1987 camaro roller with lots of performance parts 800.will not go lower have over 1500 invested.
might have more stuff. cleaning out Garage.
1982 honda v45 magna 750.. no title great for parts does run and shift $300.
t tops for 76 77 olds cutlass set. $ 150
uniden grant xl $25 has been tuned and has extra channels.
uniden washington base station has been tuned and extra channels. $40
nordic track recumbdent cycle r400 audio cycle wa s 450 last year only about 2 hrs riden if that. 150 . still 390 at sears.
make an offer.
make an offer.
Car: 1980 Chevy Stepside
Engine: 5.7L 350
Transmission: TH350
Axle/Gears: 3.73 L-Slip
Re: 200r4 ... 292 cam with lifters Lower delaware plus lots other parts
would u be willing to ship the block if so how much shipped to 39110, get back at me asap please
what are specs on that cam? is it used? how many miles? pics to game_ova223@yahoo.com also u have paypal?
Want a title? Post!
It is used, has about 200 miles on it. I took it out when i went to solid lift cam. i have pay pal.
spec. can be found here.
http://www.compcams.com/Cam_Specs/Ca...x?csid=81&sb=1
will get picts when i get home
your looking about 150 to 200 i would only charge the amount they charge me. i would perfer not to ship. if you found it cheaper for shipping let me know . my zip is 19945. i would have to charge 25 more so i could put it on a pallet and take it to the shipping center
1 Post
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Want a title? Post!
will send them as soon as i get off work
1 Post
Ok Ill look at them after work tonight.
Engine: 5.7L 350
Transmission: TH350
can u give me a rough estimate of about what the block weighs i'm thinking around 120lbs if that much. what do u think
Want a title? Post!
i Was thinking about 200 250 i know i cant handle it my self so 150 to 250
Want a title? Post!
make some offers any reasonable offer will not be refused...
cleaning out the shop.
1987 camaro rs no motor no trans. lost a performance stuff for drag racing
axles spool spohn adj torque arm. with loop and th 350 crossmember.
got over 1500 in to it. make an offer
Engine: 5.7L 350
Transmission: TH350
can i get some pictures of the 400 please and thank u
Want a title? Post!
Want a title? Post!
Want a title? Post!
Make some offers you never know you just might get it.
also have a 2005 suburban with an 8.1 big block with 41,000 miles had a tree fall on it. drive as if nothing happened to it. $3500
1992 Trans Am
05-10-2023 07:19 PM
