847 cam Lt4 rockers
847 cam Lt4 rockers
I have a brand new GM performance 847 cam for sale $175.00
I also have a set of slightly used LT4 rocker arms $175.00
email me with any questions or PM me
bubbiehead86@hotmail.com
Re: 847 cam Lt4 rockers
Brand: GM Performance Product Line: GM Performance Parts Hydraulic Roller Camshafts Part Type: Camshafts Part Number: NAL-12370847 Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 2,000-6,800 Intake Duration at 050 inch Lift: 234 Exhaust Duration at 050 inch Lift: 242 Duration at 050 inch Lift: 234 int./242 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.539 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.558 in. Valve Lift with Factory Rocker Arm Ratio: 0.539 int./0.558 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. Computer Controlled Compatible: Yes Quantity: Sold individually. Camshaft, Hydraulic Roller Tappet, Duration at .050 in. 234/242 , Lift .539/.558, Chevy, Small Block, Each
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
