Reed Cam & Howards Direct Lube Lifters
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
NEW Reed custom ground solid cam with direct lube lifters. cam was for my 388 because of that it was ground on a small base circle.
SPECS
lift .564in .572exh
dur @.050 .264in .268exh
adv duration .296in .300exh
107* LSA
it an the lifters have never been out of the plastic. I have over $330 in just the cam and lifters, heres a link to the lifters http://www.competitionproducts.com/p...umber=651080DL
I will also throw in a new set of bolts, cam lock plate, and a lifter valley oil baffle
pics http://good-times.webshots.com/album/564132932yYcWnY
$200
SPECS
lift .564in .572exh
107* LSA
$200
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
