Accel DFI 6.0
Accel DFI 6.0
F/S Accel DFI 6.0, PN 74350-c. this is a direct plug and play with the 730 ecm in f/y bodies. i just recently purchased it from another member of TGO. the ecm piggybacks the factory computer. i never used it, instead i went the chip burning route. it needs an older computer to operate. im including the wiring and map sensor harness, as well as an instruction/tuning manual and software. in the short amount of time i had it i did manage to snag the serial cable that came with it so i will take a 100 dollar hit on this. you can buy them for 75, or if your good with a soldering iron, this one can be repaired. asking $400, plus shipping. NO TIRE KICKERS! it is what it is, theres alot of info on this on the internet and TGO. I prefer paypal,but will take a money order. i can email pics at your request
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: Accel DFI 6.0
Tell me about the wire harness. Is it an interface harness or a complete FI harness.
I am very familiar with DFI 6.0
Re: Accel DFI 6.0
its an interface harness. the factory connectors plug into the accel ecu and the ecu plugs into the factory computer. the only other connectors is a map harness that uses the factory map plus another map sensor. i never used it so im not sure why you need 2 map sensors.
efiguy
09-27-2015 01:30 PM
e3pres
09-09-2015 01:51 PM
