Professional products external balance 8" harmonic balancer NEW! unused!
NEW AND UNUSED! still in wrapping and box with stickers and instructions! come with gloss black coating and white numbers for easy reading... and 60degrees of individual timing marks! and 90 degree timing MARKS around whole balancer!!!
proffessional products external balance 8" harmonic balancer... can be used on all 350s/383s/400/s etc. stock harmonic balancers are only rated to 5,000 rpms these are rated to 6,500 and arent just pressed together they are bonded! What is Bonding? When we say our dampers are bonded, what does this mean? It means that the elastomer (rubber) that is sandwiched between the ring and the hub is bonded, or vulcanized, to metal. This is similar to the process used to bond the metal motor mounts to the rubber vibration isolaters used in these mounts. This greatly increases the safety of the damper as most stock, and many inexpensive aftermarket dampers, are just pressed together and under heavy duty applications, the ring can rotate, moving your TDC mark from the true position, or fly off the engine. And that is very bad!
Our great new street Balancers are made from extremely tough nodular iron and are suitable for all street applications and mild (non SFI) racing applications. These dampers are designed to be safely revved to as high as 6,500 rpm. Our dampers are of the highest quality and are precision machined to tolerances tighter than OEM. They come with a gloss black paint finish and white timing marks for easier reading. Externally balanced dampers feature bolt-in counterweights that are precision balanced. Counterweights are included with all external dampers.Counterweights are sold separately in case you buy an internal balance damper and want to make it into an external balance. You simply buy the 400 counterweight and bolt it into the 350 damper
prices vary on net... but are around 65 or higher not including shipping. price is 40$ plus shipping. PM me if interested
monte87cortez
09-26-2015 08:10 PM
