NOS Cheater Nitrous Oxide Systems
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Kit is brand new in the box. Bought it for my Camaro but decided not to attempt the put it on. This kit is $521 at both Summit and Jegs so I feel $400 is a reasonable price considering the kit has never been used. Will accept offers but no lowballing.
Below is the summary of the kit from Summit's Website
NOS Cheater nitrous oxide systems are designed with the serious racer in mind. They feature larger nitrous and fuel solenoids than the Powershot systems and can be adjusted in a matter of seconds to add an additional 150 to 250 hp, simply by changing fuel and nitrous jets. They use a thin, 1/2 in. injector plate that fits between your carburetor and intake. Highly accurate spray bars within the plate simultaneously inject both nitrous and fuel into the manifold, creating a smooth rush of extra power on demand. They are not recommended for intake manifolds with a separate inlet for each carburetor throttle bore, except for 3 x 2-barrel setups.
Kits come complete with:
* Unfilled 10 lb nitrous bottle
* Cheater nitrous and fuel solenoids
* Injector plate
* Filters
* Fittings
* Four stages of jets
* Switches
* Aircraft-quality stainless steel braided hose
* All other necessary hardware for a complete installation
-This kit can be modified to use with any vehicle.
* Injector plate
* Filters
* Fittings
* Switches
Re: NOS Cheater Nitrous Oxide Systems
No I do not have any pictures of it. It is still in the original box.
The part number is NOS-02001NOS
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
ITs a good deal but I just spent all the money on some other parts. Good luck with your sale.
Hotrodboba400
12-10-2019 07:07 PM
