Parting '91 Firebird, rebuilt V6 3.1
Old 09-13-2008, 10:09 AM
flyfirebirdfly's Avatar
Car: '91 V6 Firebird
Engine: V6 Chevy 3.1 (modified bore)
1991 Firebird w/ rebuilt AT Chevy crate 3.1 V6 182 HP. Motor has 75k miles on rebuild. 3.1L LH0 60° V6 engine features mildly ported & blended aluminum heads, Lunati roller camshaft (Duration 292/ 296, Lift .434/ .463), roller lifters, roller rockers, double roller timing chain, notched flat top pistons, multi-port fuel injection. Bore was increased to 92 mm from 89mm (utilizing notched 3.1L LQ1 V6 pistons), but the 3.1 L engine's 84 mm stroke was retained.
Rebuilt transmission w/ shift improver kit and mild stall converter. Rebuild has approx. 65k miles on it.
I have all of the paperwork on the rebuilds, so if you have a question, just ask.
* New Alternator
* New EGM Control Valve
* New Starter
* New Battery
If you need a part, let me know and I'll get a picture of it.
More pictures can be found at: http://s466.photobucket.com/albums/rr22/edspader/car/
Old 09-13-2008, 11:19 AM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
Re: Parting '91 Firebird, rebuilt V6 3.1
Have a drivers side cupholder?
Old 09-13-2008, 11:34 AM
No, was searching for one myself.
Old 09-17-2008, 09:54 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
How about spindles for the front calipers?
Old 10-05-2008, 02:24 AM
1froggy1's Avatar
Do you have the ac tube from condenser to accumulator? also the air bag mounting bracket?
Old 10-05-2008, 04:47 AM
LD1985's Avatar
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
Do you think the engine wiring harness is the same as a 91 camaro?? If so how much?
Old 10-05-2008, 08:02 AM
bonesbrakr's Avatar
Looking for both front lower control arms. Need the ball joint sockets to be tight and not loose. If available shipping to NNJ 07508.
Bill
Old 10-06-2008, 07:59 PM
91chevywt's Avatar
How much do you want for the trans? Do you have paperwork for when it was rebuilt for labor or parts? Where/who did the trans?
Old 12-04-2008, 02:04 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Anything good about the intake, or is it just... red?
New alternator you say? I could use that if you still have it. Any other 3.1 preformance parts you have lemme know.
Elephantismo
02-13-2019 12:51 AM
the_nikfive
08-11-2015 02:46 AM
guy76767
08-06-2015 05:58 PM
XxMoLexX
02-07-2001 05:36 PM
Quick Reply: Parting '91 Firebird, rebuilt V6 3.1
