Completed TPI setup for sale (SLP, MSD etc)
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I have for sale, the most complete setup the most nicely put together setup you can get.
Here is what you get:
Upper Plenum
Lower manifold (middle bolt holes were slotted)
SLP High Flow runners
19lb injectors
Aluminum fuel rail.
Rubber fuel lines.
48mm TB
Formula TB plate
Electronic Distributor
Accel Cap and rotor
MSD new style Coil
All ducting
K&N filter
TPS sensor
IAC
Knock sensor
MAF sensor
Coolant temp sensor
MAT sensor
ESC
Fuel pump relay
MAF relay
MAF burnoff relay
MAF metal bracket
7165 ECM (tell me what size engine you have I have some memcals that may work)
Engine wiring harness meant for 5 speed with VSS (1988)
aluminum water neck
180* thermostat
Oil pressure sensor
Everything you need to have a complete TPI induction.
Price is $800 SHIPPED to lower 48. OBO
Paypal accepted add 3.5%
Money Order accepted
Personal check (will hold until clears)
MSD wires are NOT included.
Upper Plenum
19lb injectors
Aluminum fuel rail.
Rubber fuel lines.
48mm TB
Formula TB plate
Accel Cap and rotor
MSD new style Coil
All ducting
K&N filter
TPS sensor
IAC
Knock sensor
MAF sensor
Coolant temp sensor
MAT sensor
ESC
Fuel pump relay
MAF relay
MAF burnoff relay
MAF metal bracket
aluminum water neck
180* thermostat
Oil pressure sensor
Car: GTA
Engine: 383 HSR
Re: Completed TPI setup for sale (SLP, MSD etc)
Folks, please send reasonable offers.
The SLP runners were purchased two months ago for $350. The coil 2 months ago for $55 Most sensors are new.
You get a complete 100% harness and shipping is included.
This is alot of stuff. Alot of weight.
Terrell351
06-13-2021 01:13 PM
