GEN II LT1 ENGINE PARTS F/S
Engine: 355 6"rod tbi - in the works
alright, i'm trying to clear out my parts room upstairs at the shop guys, so feel free to offer whatever you want to pay. I forgot to bring my digital camera to the shop today, so I will set up pictures within a day or so. Parts are in san antonio, texas. local pickup or i can freight it.
GEN II // 350 BLOCK // OEM ROLLER // NEW FREEZE PLUGS, OIL GALLEY PLUGS, & CAM BEARINGS
CASTING # 10125327 STAMPED GM 5.7L AND 327 ON SIDE // VO# 509XPN - CYLINDERS ARE HONED / DID NOT MIC BORE
NO SURFACE RUST ON BLOCK OR IN CYLINDERS
GEN II LT1 INTAKE #12552138 // COMPLETE WITH FUEL RAILS, INJECTORS,
MAP SENSOR, THROTTLE BRACKET AND F.P. REGULATOR
NOTE - DRIVER SIDE 2ND OR 3RD BOLT HOLE APPEARED TO HAVE BEEN CUT OUT, LOOKED CLEAN
TIMING COVER WITH LOWER SENSOR
PARTS BOX WITH MISC. BRACKETS/PARTS IN VARYING CONDITION FROM GOOD - POOR.
CLEAN OIL PAN WITH WINDAGE TRAY
ALL CONNECTING RODS STILL ON PISTONS - GOOD CONDITION
PARTS BOX WITH ROLLER HARDWARE // ROLLER LIFTER KEEPERS & LIFTER HOLD DOWN TRAY //
ROCKER ARMS, PUSHRODS, & ROLLER LIFTERS - REC. REPLACING DUE TO LIFTERS SITTING.
REBUILD FACTORY ALUMINUM CYL. HEADS // CASTING# 10207643 - 5026 // HEADS ARE CLEAN,
SURFACED AND APPEAR TO HAVE HAD VALVE JOB, CAN SEE NEW GUIDES/STEM SEALS.
CRANK WAS MACHINED, BUT DUE TO SITTING HAS SURFACE RUST ON REAR MAIN BEARING JOURNAL
CENTERBOLT VALVE COVERS
1992 Trans Am
08-08-2015 08:16 PM
