GEN II LT1 ENGINE PARTS F/S
Engine: 355 6"rod tbi - in the works
alright, i'm trying to clear out my parts room upstairs at the shop guys, so feel free to offer whatever you want to pay. I forgot to bring my digital camera to the shop today, so I will set up pictures within a day or so. Parts are in san antonio, texas. local pickup or i can freight it.
GEN II // 350 BLOCK // OEM ROLLER // NEW FREEZE PLUGS, OIL GALLEY PLUGS, & CAM BEARINGS
CASTING # 10125327 STAMPED GM 5.7L AND 327 ON SIDE // VO# 509XPN - CYLINDERS ARE HONED / DID NOT MIC BORE
NO SURFACE RUST ON BLOCK OR IN CYLINDERS
GEN II LT1 INTAKE #12552138 // COMPLETE WITH FUEL RAILS, INJECTORS,
MAP SENSOR, THROTTLE BRACKET AND F.P. REGULATOR
NOTE - DRIVER SIDE 2ND OR 3RD BOLT HOLE APPEARED TO HAVE BEEN CUT OUT, LOOKED CLEAN
TIMING COVER WITH LOWER SENSOR
PARTS BOX WITH MISC. BRACKETS/PARTS IN VARYING CONDITION FROM GOOD - POOR.
CLEAN OIL PAN WITH WINDAGE TRAY
ALL CONNECTING RODS STILL ON PISTONS - GOOD CONDITION
PARTS BOX WITH ROLLER HARDWARE // ROLLER LIFTER KEEPERS & LIFTER HOLD DOWN TRAY //
ROCKER ARMS, PUSHRODS, & ROLLER LIFTERS - REC. REPLACING DUE TO LIFTERS SITTING.
FACTORY ALUMINUM CYL. HEADS // CASTING# 10207643 - 5026 // HEADS LOOK VERY CLEAN, WERE SURFACED AND APPEAR TO HAVE HAD VALVE JOB, CAN SEE NEW GUIDES/STEM SEALS // SCREW IN STUDS //
CRANK WAS MACHINED, BUT DUE TO SITTING HAS SURFACE RUST ON REAR MAIN BEARING JOURNAL
CENTERBOLT STYLE VALVE COVERS
Re: GEN II LT1 ENGINE PARTS F/S
I don't have a minimum I need for any of the parts, just want to get rid of them since we're moving into another shop and that will be one less motor to move, so I'm really open to any offer. Did you want to see pictures of the heads and then make an offer?
Car: 87 Iroc Z-28
Engine: 350 tpi
Axle/Gears: 3:27
If you still have lt1 heads? Will they fit on 87 L98 Iroc 350, or Gen 1 block?
heads will need to go on a lt1 block to work right, the coolant is sent from the w/p up to the top of the motor right away, unlike a gen 1 sbc.
green can you pm me your zip code so i look up a shipping fee.
i'm really not going to turn down any offers on these parts guys.
Alright, today on the shelf wrapped up in a bag i found the cam from this motor. It's the 242 cam, which has the bigger pilot hole and longer pin. it's the HO cam for the 95-97 aluminum head lt1 motors. so this is up for grabs also.
ok here's a rough asking price since offers aren't coming in. i'm in a hurry. everything is obo.
block - $100
intake assembly - $50
cam - $10
timing cover - $10
all rods/pistons - $30
parts box with brackets/misc. - FREE
oil pan - $10
valve train parts - $15-20?
crank - $20
valve covers - $5/pair
heads - $300 - pending with green
block - $100
cam - $10
timing cover - $10
oil pan - $10
crank - $20
is 95012 california? your location says CO. anyway it lists shipping at $60 online, but i know that is way too much, it was $25-30 last time i shipped 2 cast iron vortec heads to oregon. so I'd say $30 shipping, i always refund extra shipping if i don't use it all.
i had two PM's for the cam. the cam was pulled from a running motor, bagged and put in the bottom corner of the big parts box with the small parts boxes in it, so nothing heavy or damaging sat on it, i did not mic the lobes, i just inspected for grooves or scratches on the lobes and journals, I didn't see anything noticeable, I will look it over again today and try to mic it if i get the chance.
replied to PM's.
replied to PM's.
Car: 89 RS Red
Engine: 2.8L
95012 is CA. I just moved to Monterey Area. I have been doing a but of research on the heads. I have a TPI intake that I want to use but the pattern is different. I bought it from Summit a while ago. I am trying to see if they will let me exchange it for the matching intake. Can you hang on to the heads for me? I will get back with you on Friday. One question though, what is bump?
eh, some people post "bump" to bump their topic back to the top of the 1st page the forum, as it had reached the bottom of the 2nd page. I'll hang on to the heads til friday.
1 Post
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
what all has been sold?
I still see no pics of anything.
Car: 82 T/A
Engine: stock 350
Ill take PARTS BOX WITH ROLLER HARDWARE // ROLLER LIFTER KEEPERS & LIFTER HOLD DOWN TRAY //
I'm in Austin, and will take the whole box for $20 if you can ship here. I have all my part delivered to my warehouse, so no residential cost. Also, do u take paypal?
Car: 89 RS Red
Engine: 2.8L
Thanks for holding them for me. I won't be able to get the heads. So it looks like some one is going to luck up here. Sorry for the inconvience.
1 Post
I think this guy bailed out on us.
He hasn't been here in over a week!
If he really wanted this stuff gone don't ya think ya woulda had a response by now?
I was ready to purchase the cam for $10!!!
When I replied,he just vanished!
1992 Trans Am
08-08-2015 08:16 PM
