Computer/engine harness "88 TPI car"
Car: 1988 IROC-Z
Engine: LS2
Axle/Gears: Strange 60 3:73
Working harness/computer removed from my car, the harness is separated from the rest of the car (lights, gauges, etc) How's $100 shipped? Worked fine, just removed my engine and no longer need it. I am going to try and part my motor out piece by piece for more solid leads.
Will
Will
Car: 1988 IROC-Z
Engine: LS2
Re: Computer/engine harness "88 TPI car"
It is from a 305/5 speed So it should be exactly what you are looking for.
Just want to confirm the wiring for under the hood is uncut from ecm to all the tuned port stuff, and that the ecm still has the chip in it, if so do you take paypal, LMK
Car: 1988 IROC-Z
Engine: LS2
Everything is there that would be required to run the motor itself, i have separated it from the other part of the harness. I'll have to double check all connectors are ok, and make sure i'm not forgetting anything. The computer comes complete with chip. I'll pm you my paypal when i check and see everything is ok, otherwise, ill let you know differently.
Will
Will
thanks as long as the connectors are there thats what Im looking for, no concerned about the headlight, cruise or heater wiring which is what Im assuming you were talking about
IBrockZ
08-20-2015 12:20 PM
Sanjay
08-12-2015 03:41 PM
