Fresh 355 sbc complete unassembled long block
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Selling complete, unassembled 350 sbc with 083 TPI heads. One pc rear main seal , Fully prepped 350Block is .030 over, coated skirt hyperuetectic pistons w/moly rings. Recon rods, polished crank, rebuilt 083 tpi heads, 1.6 long slot rocker arms, complete gasket set, head gaskets, oil pump , double roller timing set, new cam and lifters(non-roller)...cam specs will work great with 4bbl carb or slightly modded TPI set-up(similar to ZZ4 specs)....I have every nut & bolt needed to assemble this motor. Included is the flywheel & balancer as well. All you really need is the intake and distributor. See pictures, if I left something out just ask. Must be picked up in NY zip 11772. Looking to get $1200 for everything.....money talks.....Dean cell# 516 316-6451
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Re: Fresh 355 sbc complete unassembled long block
I will be happy to assemble motor for a fee.
Terrell351
06-13-2021 01:13 PM
MoJoe
09-24-2015 09:12 PM
