Heads, Intake and other parts
I posted some LT1 parts too since I know some guys(myself included) have or are about to have LT1's in their 3rd gens.
LT1 Heads/Intake/Injectors had 50k(ish) on the meter when removed.
Check my imageshack for plenty of photos
Everything is obo and I'm open to some trades.
Stock LT1 Cast Iron Cylinder Heads with Spring/Valves 10125320... 130 shipped obo
I still have the rockers also. Heads still have Head Gaskets on in the pictures, I left them on so the surface wouldnt get scuffed from storage.
Stock 95 Lt1 Intake... 35+ shipping obo
It hasnt been cleaned since it was removed a few weeks ago but if no one wants it, Ill clean it and paint it to make it look better. With a price adjustment
Stock LT1 24lb Injectors... 25 shipped obo
All Orings are there and physically look fine(some Orings have some wrinkles in them)
Edelbrock Carb Intake Manifold (Gen I motor) 60 shipped
Intake is very clean. Selling the 2 inch spacer in the pic for 5+ shipping or free if you want it with the intake.
In this picture, Im selling the headers. Well, eventually Ill be selling anything on that motor and the 700r4, I just have to get around to pulling them. If you have any interest in Plug wires, intake, trans or anything else just let me know and I'll try to pull them. Its been raining for almost a week straight so I haven't had a good day to do it.
Thermal Coated Hedman Hedders for a Gen I 305 or 350... 115 shipped
They are P/N 68478
New Pics of headers are up.
Also selling that AC delete Pulley for 25+ shipping.
Dayco AC delete Belt 10+ shipping
I have the longer belt to skip the Smog Pump pulley that Id be willing to sell aswell. It was the most expensive belt they had since I had some problems with the cheaper one.
I have the Smog Pump delete Pulley as well but I'm holding it till the beginning of the month for someone.
Valve Covers Gen I Centerbolts, never been installed! I purchased a set and a friend gave me another. 25 shipped
I also have the same set that are used with some wear for 15 shipped
And stock LT1 valve covers with some wear on them for 15 shipped
photos, on the used ones, on request
2 set of Trans Dapt Valve Cover Bolts #9812, Never opened (1 set includes 8 bolts, enough for both valve covers)... 10 shipped
I also have some 081 casting Gen I cylinder heads for 120... shipped
The 081 castings are a 305 cylinder head but alot of people put them on 350's because of the small combustion chambers for higher compression and have got great results with porting too.
http://profile.imageshack.us/user/genhero/
There are plenty of photos at my imageshack but I didnt want to spam this thread with tons of pictures. I seperated them into categories. When you go to the link, at the top right it will say Tags, click on the tag you want for those pictures. C1 is one of the LT1 cylinder heads C2 is the other. If you would rather not use imageshack or can not see the photos, just PM me your email and what photos you want sent.
They are P/N 68478
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Heads, Intake and other parts
pics on the ac delete pulley to godreject@msn.com and condition thanks
Prices Also changed.
Yes they will work. It will need to be tuned or it will run rich but seeing as you have a cam you(or someone you know) already knows how to tune.
-Russ
-Russ
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
I bought the car with the cam in it. However, I'm starting to seriously doubt that this car has an upgraded cam.
I'll do some research before I give you a final answer.
081 Heads Sold
Injectors Sold
I also have a serp. setup for 75+ shipping
Includes both brackets w/ tensioner(alt bracket has a piece cut out so I could run a smaller bolt where the smog pump went, so smog pump cannot be installed on this), WP pump pulley, PS pump pulley and belt to run smog delete. I dont have an AC compressor pulley but I still have the AC delete pulley for sale.
Injectors Sold
I have the LT1 cam that is a Roadmaster/Impala cam. Its a bit different than the Fbody one, but yes I do still have it and can pull it if you are interested.
-Russ
-Russ
Car: 1989 TransAm GTA
Transmission: 700R
I know this thread is a few months old; but I need some of the silver color center bolt valve covers for my 89 GTA.
Thanks!
Thanks!
86IROC112
08-17-2015 02:00 PM
