2007 L92 Longblock and L76 Intake Setup w/Holley 90mm TB
1 Post
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
07 L92 Long Block. Still on Crate. Zero Miles. Originally it had a truck intake on it but was sold to buy the car intake. This is virtually the same as an LS3. The main differences are: This has solid intake valves instead of hollow stemmed ones, slight exterior differences on intake- Internally the intakes are the same. 10.5:1 compression instead of 10.7:1 compression due to valve reliefs in the pistons. These however allow you to run a much larger cam w/o having to flycut the pistons like you do on LS3's. This has the VVT and AFM unlike the current LS3. Also comes with the truck water pump, exhaust manifolds, flexplate, and passenger side accessory bracket.
With a moderate cam change and spring upgrade this motor is an easy 480-510 rwhp motor with good driveability.
4500.00
Complete L76 Intake with Holley 90mm TB and LS7 Injectors. All Brand New Parts except Injectors, which have approximately 2000 miles.
1000 plus actual shipping.
Various L92/Gen IV Swap Parts. GM 24x Reluctor Wheel, GM 1x Cam Gear, Katech MAP Extension harness, Racetronix Knock Sensor Harness, Racetronix Cam Sensor Harness, LS2/LS3 Valley Cover with new gaskets.
Or 5500 for everything above. I'll ship if you make the freight arrangements with a terminal within 60 miles of my location. I'm located in Chesapeake Ohio 45619 (Right across the Ohio river from Huntington WV.
4500.00
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
Re: 2007 L92 Longblock and L76 Intake Setup w/Holley 90mm TB
sweet engine
1 Post
Prices Reduced
4200 for long-block with swap parts.
4000 for long-block only
900 for complete intake w/throttle body
425 for throttle body
500 for complete intake w/o throttle body
OR
5000 for everything
Prices do not include actual shipping. Add 3% for paypal.
OR
5000 for everything
1 Post
the etecs sold over a month ago.
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
